Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.09
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Worked: 2.93.6
Caused by rB3b6ee8cee708: Refactor: Move vertex group names to object data
Blender crashes on mesh edit if the mesh has a curve modifier with both a vertex group set and the edit mode display option toggled on.
The crash seems to depend on both being set, both options work normally when used independently (remove the vertex group or turn off the edit mode display option on the modifier and edit will still work).
Open attached .blend file.
Select the plane.
Press tab to go into edit mode - Blender will crash.
Either remove the vertex group or turn off the edit mode display option on the modifier and it won't crash.
Thank you!
