Bevel Modifier Overshoots/Explodes the Mesh
Closed, DuplicatePublic
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Worked: 2.93.6
Bevel modifier overshoots heavily, causing a kind of "exploded" geometry around some bevels.
Not quite sure how to reproduce, the mesh has been created using boolean cuts and unions with Hardops and Boxcutter. Over a dozen other parts of the model bevel just fine. I attached the a blend file with the problematic geo in question, enabling/disabling the modifier in 3.0 shows the bug.
Opening the very same file in Blender 2.93.6 works fine as before.
Blender 2.93.6
Same in 3.0
Just noticed when I untick "Loop Slide" the bevel is fine.
This is the same problem described in T89622: Bevel on tight corner limitation.
I'm still not sure if it's a bug or a limitation.
Need developer information.
