Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Distribute memory across devies (Optix ) is in Blender 3.0 broken
- Open the attached blend file in Blender 3.0.
- Ensure that you have 2x RTX 2080TI with NVLink and enable "Distribute memory across devices" in OptiX
- Click on render
- Render will crash with this error:
Failed to build OptiX acceleration structure OPTIX_ERROR_INVALID_VALUE in optixAccelBuild(context, 0, &options, &build_input, 1, temp_mem.device_pointer, sizes.tempSizeInBytes, out_data.device_pointer, sizes.outputSizeInBytes, &out_handle, use_fast_trace_bvh ? &compacted_size_prop : 0, use_fast_trace_bvh ? 1 : 0) (C:\Users\blender\git\blender-v300\blender.git\intern\cycles\device\optix\device_impl.cpp:1066)OPTIX_ERROR_INVALID_VALUE in optixAccelBuild(context, 0, &options, &build_input, 1, temp_mem.device_pointer, sizes.tempSizeInBytes, out_data.device_pointer, sizes.outputSizeInBytes, &out_handle, use_fast_trace_bvh ? &compacted_size_prop : 0, use_fast_trace_bvh ? 1 : 0) (C:\Users\blender\git\blender-v300\blender.git\intern\cycles\device\optix\device_impl.cpp:1066)
Additional informations
- "Distribute memory across devices" is working in CUDA mode (Blender 3.0)
- "Distribute memory across devices" in OptiX is working in Blender 2.93 - you can open the attached file in 2.93 and will see it's rendering.
- The attached file requires 17GB VRAM in OptiX in Blender 2.93. If you have 2x RTX 3090 this bug can be maybe also reproduced by increasing the required VRAM over 24GB, just duplicate some Suzsannes. I was only able to test it on 2x RTX 2080ti because my lack of 3090s ;)
Thank you for your help
