Operating system: Linux-5.11.0-41-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.91.03
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Make instances real for geometry nodes makes the entire instances Per Vertex
Select an object that contains a geometry nodes tree
CTRL + A > Make instances Real
There seems to be a "trick" when using the Object Info node: that is using the As Instance checkbox (but dont think this is the intention on this option -- and even if: this would be pretty intransparent, and also missing for primitives)
Disabling the As Instance option will create many objects with the whole realized geometry in them.
