Boto3 error
Operating system: Windows 11 64bit home
Graphics card: AMD Radeon 6700xt
Broken:2.93,3.0
(example: 2.79b release)
ON attempting to install Radeon pro render I just keep getting a traceback error on attempting to enable that it can not find boto3, I attempted to install boto3 in python using pip command, didn't work for blender, did nothing kept getting errors, uninstalled blender reinstalled 3x to no avail, deleted appdata, did nothing, deleted temp data did nothing, deleted all user data did nothing, uninstalled all versions of python did nothing, really getting annoyed.
If you are able to fix this, let me know! I'm having the same issue
im also getting the same error , my graphic card is rx 6600m
The Radeon pro render addon is not maintained by blender, so this bug tracker is not the ideal channel to report problems in this addon (since the author probably won't be notified).
Please report the issue to the original author instead.
thank you so much the weekly build fixed that for me .😥i installed python and gone through tons of vedios ,finally its resolved ,alhamdulillah
