geometry nodes and remesh - material bug
Closed, DuplicatePublic
Graphics card: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
the object material is not assigned if you use geometry node mesh primitive instance and remesh modifier after
  1. add geometry nodes to an object
  2. distribute point on face
  3. instance mesh primitive on point (like icosphere)
  4. add realize instance node
  5. add material (it will be show up)
  6. add remesh modifier (the material will be unassigned)
it works well if you use as instance an object in scene instead of a mesh primitive inside geometry node
Hi, thanks for the report. This is not a bug but working as expected as said in T93607: Remesh Modifier loses reference from Set Material in Geometry Nodes.
So I will mark this as duplicate. Feel free to reopen or comment if I misunderstood your reported issue.
I saw the other report but I think it's not the same problem, in this case I can't assign any material, even on the first slot. I mean you have no way to shade your model, I think it's not properly correct.
