Blender Camera Background Video Crash
Closed, DuplicatePublic
Operating system: Windows 10
Graphics card: NVIDIA GTX 1050
Broken: Blender 3.0
Worked: 3.0 Alpha Daily Build Probably
Switching from Rendered View to Solid View in EEVEE while playing background reference video in Camera View, crashes Blender.
Start with a new default scene. Go to Camera View, and then load a Reference Video using Background Images in the Camera Options Panel. Finally, play the video, in Rendered View in EEVEE, when you switch to solid view, it will crash Blender immediately!
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Dec 16 2021, 10:52 AM
Hi, Thanks for the report. Can not reproduce here on master and 3.0.0.
Please send log files generated after the crash: https://docs.blender.org/manual/en/dev/troubleshooting/crash.html#crash-log
Also please check if you can reproduce crash with factory settings: FileDefaultsLoad Factory Settings
Here are the two files...
Hi, thanks for sending crash logs.
Does that work for you?
May be I am trying to repro in a wrong manner. Can you please check the video?
You must start playing it, and while the video is running, switch between solid to rendered.
You see, you loaded up the video, and then just started switching between solid and rendered. I do that too, and it doesn't crash
But if I press play on the animation timeline, while the video is running, if I switch between solid and rendered, it crashes.
Here's a Video I attached showing the crash in action.
Hi, this is something which I can not reproduce frequently. 3.0.0 crashed for a couple of times but build on master branch(3.1.0) works fine here.
@Blender Bach (blenderbach), any luck with 3.1.0? Still crashing?: https://builder.blender.org/download/daily
Similar problem has been reported and closed recently: T94266: Crash with Movieclip background in Camera view
(Both appears to be same issue)
This is indeed fixed, see T94266: Crash with Movieclip background in Camera view.
Will merge reports, see the other report where to get a working build (but of course feel free to comment again if issues persist).
How is this even possible? Blender 3.0 is a stable version, yet Blender 3.1 is more stable than the stable version? 😂
You're all fired! 😂
Just kidding!
Thanks for the information!
