Blender crashes when linking curve modifier in edit mode with vertex group
Closed, DuplicatePublic
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
When linking a mesh's vertex group to a curve as an influence, and with 'Edit Mode' and 'On Cage' checked, after going into Edit Mode the application crashes.
Add a plane
Add a bezier curve
Select the plane, then create vertex group and assign some vertices
In Modifiers, add a Curve Modifier
Link plane to curve
Select vertex group as influence
Select 'Display Modifier in Edit Mode' and 'On Cage'
Tab and go into edit mode
