Node presets are not stored in designated file
Graphics card: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Addon Information
Name: Node Presets (1, 1)
Author: Campbell Barton
[Node presets are not stored in designated "templates" file]
[1. Select nodes and group them
  1. the nodes group should be able to be found in the template file (in shader editor's "Add" menu)]
Hi everyone,
I've been trying to save my nodes using the "Node Presets" Add-on. When I go through the steps I don't find any .blend files of the node groups in the designated file, so I can't load anything from shader editor's Add menu. I might be doing the wrong thing. I went to Blender's manual and couldn't find any description of how to use this Add-on.
Any guidance is appreciated
In the Add-ons preferences, you will find a path that points to the directory where presets are stored. Put blend files that includes the needed node groups in that directory and you should be able to add them to your project. But the add-on doesn't store groups automatically, so this is not a bug.
