Rendering Errors with Motion Blur in Blender 3.1
Operating system: Win 10 21H2
Graphics card: GTX 1070 - Studiodriver V. 472.39
Broken: Blender 3.1.0 - Alpha December 31, 02:07:49 - bf4358ed0c54
In this example I have extreme motion blur settings for a particle animation.
However, it also happens in other scenes with normal motion blur settings that individual images are rendered without motion blur or shattered.
Blend:
Eevee:
Cycles:
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jan 7 2022, 5:26 AM
Glitch in first video happens probably because all caches must be baked before rendering. Issues at start and end happen, because particles do not exist before start frame and after end frame. Here I had to move whole simulation to frame 100-189, then bake from 0 - 320 (huge excess, but wanted to be safe), after that I had to set start and end frame and finally render.
I think that negative frames not being supported is already reported, but not sure about problems about baking beyond start/end frames.
Does this help? Can I change this report to above issues, or did I misunderstood this report?
Hi Richard,
thank you very much for your answer.
You're right, it's a baking problem!
Many thanks for your Help und please mark this report as solved.
Richard Antalik (ISS) closed this task as Archived.Jan 8 2022, 5:53 AM
Glad it helped. Will close then.
