3.0.0 crashes rendering with Cycles
Operating system: Windows 10
Graphics card: Geforce RTX 3090
Broken: 3.0.0
Worked: 2.93.7
Blender crashes after a few seconds when trying to render with Cycles (even with default cube).
Eevee works fine. It crashes when rendering with both GPU and CPU. Not using any addons.
Loading the .blend file
press F12
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jan 20 2022, 7:08 PM
Richard Antalik (ISS) edited projects, added BF Blender; removed BF Blender (3.0).
In file blender_debug_output.txt you uploaded here you rendered on CPU, is that correct? I have never heared about such issue that CPU rendering would crash with default cube.
Can you check if this happens with latest alpha build from https://builder.blender.org/download/daily/?
Yeah correct.
I've tried it now with the alpha build but it still crashes rendering both with GPU and CPU.
I've tried it again with 2.93.7 and it works perfectly fine rendering with either one.
Can you run blender from console with argument --debug-cycles? Perhaps that will provide more info.
Richard Antalik (ISS) closed this task as Archived.Apr 12 2022, 9:08 PM
