Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.29
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Broken: version: 3.0.1
Broken: version: 3.1.0
Keep getting CUDA errors almost as soon as I try using CUDA or OptiX.
I tried many different solutions to no avail.
Open Blender, select File > Defaults > Load Factory Settings.
In Preferences select CUDA or OptiX with the NVIDIA card.
In Render menu select Cycles, use GPU compute and remove Denoise option.
Press F12 to render, gets the following error:
Illegal address in CUDA queue copy_from_device (integrator_init_from_camera integrator_compact_states)
Some more infos
The exact message can vary slightly from time to time.
After that I have to restart Blender or even reboot. I had it working one or twice in a row but no more than that.
The issue is not limited to the default cube, it affects every scenes.
I updated windows, just did a clean reinstall of NVIDIA's driver and rebooted right before experiencing the bug again.
I also tried with the latest Studio driver, same result.
My GPU is not overclocked, I even tried underclocking it as much as I possibly could using MSI Afterburner, it might have improved it a little bit but I can't really tell if it's really the case.
I tried removing each of my RAM stick to check for any hardware corruption but it didn't change the result.
I also uninstalled and reinstalled Blender multiple times (also different versions sometimes).
My GPU is working fine with other game, I'm not excluding a hardware issue but if it is it's not an obvious one.
I know that this is not the first occurence of this issue and there might not be any solution, but I'm kinda pissed (not toward anyone, just the situation itself) to have a good machine and be forced to work on a (much slower) laptop to be able to render anything with Cycles.
I have development experience so I'm open to try stuff and get my hands dirty to find that little sneaky issue which seems to be plaguing many people!
