my inflate tool on stem isnt working
Operating system: windows 10
Graphics card: NVIDIA GeForce GTX 1050Ti
Broken: 3.0
Worked: 3.0
my inflate tool isn't working
I recently started using blender on steam and when I tried using the inflate tool the first few times it worked great but not it isn't working and I don't know why
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Jan 13 2022, 9:18 AM
Please try to be more specific an share an example .blend file along with reproduction steps (as in: what should be done after opening that file so the inflate tool "does not work" anymore).
Also: what does it mean, that it "does not work"? Doing nothing at all? Doing unexpected deformation?
the deformation instead of inflating it doesn't do anything or if I turn up the strength it will push it down if and also I did nothing special to cause this to happen it was working fine in previous weeks of me using it but for some reason now it isn't working
Please share an example .blend file
Philipp Oeser (lichtwerk) closed this task as Archived.Feb 7 2022, 10:16 AM
