object.ray_cast func is invalid
Graphics card: NVIDIA GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.09
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2022-01-12 19:46, hash: rB97c2c3991620
If the object has the 'MULTIRES' modifier and the modifier is on then the object.ray_cast of the object will fail, I don't know why this is,
如果物体有 'MULTIRES' 修改器,并且修改器是开启的那么物体的object.ray_cast将失效,我不知道为什么会这样
I'm having a problem writing a function that tests if the mouse is over a model
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Jan 17 2022, 10:53 AM
Script had the best_obj being printed in the loop [seems unintended].
This file (updated script included) works for me, @EMM (IMBI) , does it work for you, too?
