Blender 3.0.0 crashes, cannot re-open on Intel or Apple Silicon versions
Translated Report (Full Report Below)
Process:               Blender [601]
Path:                  /Applications/Blender.app/Contents/MacOS/Blender
Identifier:            org.blenderfoundation.blender
Version:               3.0.0 (3.0.0 2021-12-03)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-01-28 09:44:15.9016 -0500
OS Version:            macOS 12.1 (21C52)
Report Version:        12
Anonymous UUID:        433695DF-1121-C958-75E4-A0D5EAF921ED
Time Awake Since Boot: 64 seconds
System Integrity Protection: enabled
Crashed Thread:        20
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x000000067ffe8000
Exception Codes:       0x0000000000000001, 0x000000067ffe8000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [601]
VM Region Info: 0x67ffe8000 is not in any region.  Bytes after previous region: 15971811329  Bytes before following region: 39728545792
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      MALLOC_MEDIUM (reserved)    2c7800000-2c8000000    [ 8192K] rw-/rwx SM=NUL  ...(unallocated)
--->  GAP OF 0xcf8000000 BYTES
      commpage (reserved)         fc0000000-1000000000   [  1.0G] ---/--- SM=NUL  ...(unallocated)
Thread 0::  Dispatch queue: com.apple.main-thread
0   Blender                       	       0x10520a9a0 loop_split_worker_do(LoopSplitTaskDataCommon*, LoopSplitTaskData*, BLI_Stack*) + 260
1   Blender                       	       0x10520993c loop_split_generator(TaskPool*, LoopSplitTaskDataCommon*) + 304
2   Blender                       	       0x10520993c loop_split_generator(TaskPool*, LoopSplitTaskDataCommon*) + 304
3   Blender                       	       0x105209680 BKE_mesh_normals_loop_split + 412
4   Blender                       	       0x1051f709c BKE_mesh_calc_normals_split_ex + 372
5   Blender                       	       0x1050b4bb4 mesh_calc_modifier_final_normals(Mesh const*, CustomData_MeshMasks const*, bool, Mesh*) + 160
6   Blender                       	       0x1050b4c74 tbb::interface7::internal::delegated_function<mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**)::$_0 const, void>::operator()() const + 68
7   Blender                       	       0x1054d55a4 tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) + 92
8   Blender                       	       0x1050b35ec mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**) + 1116
9   Blender                       	       0x1050b2eec mesh_build_data(Depsgraph*, Scene*, Object*, CustomData_MeshMasks const*, bool) + 144
10  Blender                       	       0x1050b23bc makeDerivedMesh + 124
11  Blender                       	       0x10525c6f4 BKE_object_handle_data_update + 884
12  Blender                       	       0x10525ca6c BKE_object_eval_uber_data + 64
13  Blender                       	       0x1055ef768 blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*) + 140
14  Blender                       	       0x10c0f7fbc tbb::internal::function_task<Task>::execute() + 24
15  Blender                       	       0x1054e34dc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
16  Blender                       	       0x1054e2b8c tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
17  Blender                       	       0x1068603ac tbb::internal::task_group_base::wait() + 40
18  Blender                       	       0x10c0f7bfc BLI_task_pool_work_and_wait + 392
19  Blender                       	       0x1055ef55c blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph*) + 572
20  Blender                       	       0x10529bb44 scene_graph_update_tagged + 360
21  Blender                       	       0x1054ec69c wm_event_do_depsgraph + 188
22  Blender                       	       0x1054f5708 wm_file_read_post + 316
23  Blender                       	       0x1054f4be8 WM_file_read + 640
24  Blender                       	       0x1054f9ef0 wm_open_mainfile__open + 308
25  Blender                       	       0x1054effa4 wm_handler_fileselect_do + 512
26  Blender                       	       0x1054f3d6c wm_handlers_do_intern + 3192
27  Blender                       	       0x1054ef758 wm_handlers_do + 64
28  Blender                       	       0x1054eecfc wm_event_do_handlers + 1300
29  Blender                       	       0x1054e7904 WM_main + 36
30  Blender                       	       0x1050a3774 main + 924
31  dyld                          	       0x115bbd0f4 start + 520
Thread 1:
0   libsystem_kernel.dylib        	       0x1c438d990 semaphore_wait_trap + 8
1   libdispatch.dylib             	       0x1c420b13c _dispatch_sema4_wait + 28
2   libdispatch.dylib             	       0x1c420b7f4 _dispatch_semaphore_wait_slow + 132
3   Blender                       	       0x10a93778c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64
4   Blender                       	       0x10a936394 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64
5   libsystem_pthread.dylib       	       0x1c43c9240 _pthread_start + 148
6   libsystem_pthread.dylib       	       0x1c43c4024 thread_start + 8
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
0   libsystem_pthread.dylib       	       0x1c43c4010 start_wqthread + 0
Thread 12:
Thread 13:: AMCP Logging Spool
1   caulk                         	       0x1ccd968ac caulk::mach::semaphore::wait_or_error() + 28
2   caulk                         	       0x1ccd7965c caulk::concurrent::details::worker_thread::run() + 56
3   caulk                         	       0x1ccd7927c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 96
4   libsystem_pthread.dylib       	       0x1c43c9240 _pthread_start + 148
5   libsystem_pthread.dylib       	       0x1c43c4024 thread_start + 8
Thread 14:
Thread 15:
Thread 16:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        	       0x1c438d954 mach_msg_trap + 8
1   libsystem_kernel.dylib        	       0x1c438dd00 mach_msg + 76
2   CoreAudio                     	       0x1c60cfef0 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 104
3   CoreAudio                     	       0x1c5f5ee04 HALC_ProxyIOContext::IOWorkLoop() + 3360
4   CoreAudio                     	       0x1c5f5dae0 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 100
5   CoreAudio                     	       0x1c6129420 HALB_IOThread::Entry(void*) + 88
6   libsystem_pthread.dylib       	       0x1c43c9240 _pthread_start + 148
7   libsystem_pthread.dylib       	       0x1c43c4024 thread_start + 8
Thread 17:
Thread 18:
Thread 19:
0   dyld                          	       0x115befc78 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 608
1   dyld                          	       0x115befb2c dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 276
2   dyld                          	       0x115bdcec8 dyld4::APIs::dladdr(void const*, dl_info*) + 200
3   libsystem_c.dylib             	       0x1c42a2f8c backtrace_symbols + 112
4   Blender                       	       0x10c0f4cfc BLI_system_backtrace + 72
5   Blender                       	       0x1050a7220 sig_handle_crash + 356
6   libsystem_platform.dylib      	       0x1c43e04e4 _sigtramp + 56
7   Blender                       	       0x10c0f9464 void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&) + 576
8   Blender                       	       0x10c0f90c0 void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&) + 152
9   Blender                       	       0x10c0f9014 tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute() + 116
10  Blender                       	       0x1054e34dc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
11  Blender                       	       0x1054e2b8c tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
12  Blender                       	       0x1054d322c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
13  Blender                       	       0x1054dc2e4 tbb::internal::market::process(rml::job&) + 40
14  Blender                       	       0x1054dd5dc tbb::internal::rml::private_worker::run() + 288
15  Blender                       	       0x1054dd4b0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
16  libsystem_pthread.dylib       	       0x1c43c9240 _pthread_start + 148
17  libsystem_pthread.dylib       	       0x1c43c4024 thread_start + 8
Thread 20 Crashed:
0   Blender                       	       0x1051fe7cc BKE_mesh_calc_poly_normal + 16
1   Blender                       	       0x10c0f9464 void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&) + 576
2   Blender                       	       0x10c0f90c0 void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&) + 152
3   Blender                       	       0x10c0f9014 tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute() + 116
4   Blender                       	       0x1054e34dc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
5   Blender                       	       0x1054e2b8c tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
6   Blender                       	       0x1054d322c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
7   Blender                       	       0x1054dc2e4 tbb::internal::market::process(rml::job&) + 40
8   Blender                       	       0x1054dd5dc tbb::internal::rml::private_worker::run() + 288
9   Blender                       	       0x1054dd4b0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
10  libsystem_pthread.dylib       	       0x1c43c9240 _pthread_start + 148
11  libsystem_pthread.dylib       	       0x1c43c4024 thread_start + 8
Thread 21:
0   dyld                          	       0x115befc90 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 632
7   ???                           	       0x140eaae08 ???
8   Blender                       	       0x1052076f0 BKE_mesh_mirror_apply_mirror_on_axis_for_modifier + 3076
9   Blender                       	       0x1057000d0 modifyMesh + 192
10  Blender                       	       0x1050b3ab0 mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**) + 2336
11  Blender                       	       0x1050b2eec mesh_build_data(Depsgraph*, Scene*, Object*, CustomData_MeshMasks const*, bool) + 144
12  Blender                       	       0x1050b23bc makeDerivedMesh + 124
13  Blender                       	       0x10525c6f4 BKE_object_handle_data_update + 884
14  Blender                       	       0x10525ca6c BKE_object_eval_uber_data + 64
15  Blender                       	       0x1055ef768 blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*) + 140
16  Blender                       	       0x10c0f7fbc tbb::internal::function_task<Task>::execute() + 24
17  Blender                       	       0x1054e34dc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
18  Blender                       	       0x1054e2b8c tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
19  Blender                       	       0x1054d322c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
20  Blender                       	       0x1054dc2e4 tbb::internal::market::process(rml::job&) + 40
21  Blender                       	       0x1054dd5dc tbb::internal::rml::private_worker::run() + 288
22  Blender                       	       0x1054dd4b0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
23  libsystem_pthread.dylib       	       0x1c43c9240 _pthread_start + 148
24  libsystem_pthread.dylib       	       0x1c43c4024 thread_start + 8
Thread 22:
0   dyld                          	       0x115befc88 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 624
Thread 23:
0   libsystem_kernel.dylib        	       0x1c4393d00 __sigaction + 8
1   libsystem_platform.dylib      	       0x1c43df7d0 __platform_sigaction + 108
2   libsystem_c.dylib             	       0x1c42b1584 signal__ + 80
3   Blender                       	       0x1050a7288 sig_handle_crash + 460
4   libsystem_platform.dylib      	       0x1c43e04e4 _sigtramp + 56
5   ???                           	       0x29a087e08 ???
6   Blender                       	       0x1052076f0 BKE_mesh_mirror_apply_mirror_on_axis_for_modifier + 3076
7   Blender                       	       0x1057000d0 modifyMesh + 192
8   Blender                       	       0x1050b3ab0 mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**) + 2336
17  Blender                       	       0x1054d322c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
18  Blender                       	       0x1054dc2e4 tbb::internal::market::process(rml::job&) + 40
19  Blender                       	       0x1054dd5dc tbb::internal::rml::private_worker::run() + 288
20  Blender                       	       0x1054dd4b0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
21  libsystem_pthread.dylib       	       0x1c43c9240 _pthread_start + 148
22  libsystem_pthread.dylib       	       0x1c43c4024 thread_start + 8
Thread 24:
12  Blender                       	       0x1054e0474 tbb::internal::generic_scheduler::spawn_root_and_wait(tbb::task&, tbb::task*&) + 224
13  Blender                       	       0x10c0f8d54 tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::run(tbb::blocked_range<int> const&, RangeTask const&, tbb::auto_partitioner const&) + 164
14  Blender                       	       0x10c0f80e4 BLI_task_parallel_range + 284
15  Blender                       	       0x1052081d4 BKE_mesh_ensure_normals_for_display + 444
16  Blender                       	       0x1050b4be4 mesh_calc_modifier_final_normals(Mesh const*, CustomData_MeshMasks const*, bool, Mesh*) + 208
17  Blender                       	       0x1050b4c74 tbb::interface7::internal::delegated_function<mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**)::$_0 const, void>::operator()() const + 68
18  Blender                       	       0x1054d55a4 tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) + 92
19  Blender                       	       0x1050b35ec mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**) + 1116
20  Blender                       	       0x1050b2eec mesh_build_data(Depsgraph*, Scene*, Object*, CustomData_MeshMasks const*, bool) + 144
21  Blender                       	       0x1050b23bc makeDerivedMesh + 124
22  Blender                       	       0x10525c6f4 BKE_object_handle_data_update + 884
23  Blender                       	       0x10525ca6c BKE_object_eval_uber_data + 64
24  Blender                       	       0x1055ef768 blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*) + 140
25  Blender                       	       0x10c0f7fbc tbb::internal::function_task<Task>::execute() + 24
26  Blender                       	       0x1054e34dc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
27  Blender                       	       0x1054e2b8c tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
28  Blender                       	       0x1054d322c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
29  Blender                       	       0x1054dc2e4 tbb::internal::market::process(rml::job&) + 40
30  Blender                       	       0x1054dd5dc tbb::internal::rml::private_worker::run() + 288
31  Blender                       	       0x1054dd4b0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
32  libsystem_pthread.dylib       	       0x1c43c9240 _pthread_start + 148
33  libsystem_pthread.dylib       	       0x1c43c4024 thread_start + 8
Thread 25:
0   dyld                          	       0x115befb60 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 328
Thread 26:
0   dyld                          	       0x115befbb0 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 408
Thread 27:: com.apple.NSEventThread
2   CoreFoundation                	       0x1c4494ed8 __CFRunLoopServiceMachPort + 372
3   CoreFoundation                	       0x1c4493390 __CFRunLoopRun + 1212
4   CoreFoundation                	       0x1c4492734 CFRunLoopRunSpecific + 600
5   AppKit                        	       0x1c7155c90 _NSEventThread + 196
Thread 28:
Thread 29:
Thread 20 crashed with ARM Thread State (64-bit):
    x0: 0x00000002c0116f44   x1: 0x00000004a0068008   x2: 0x00000002c0070008   x3: 0x00000002c0146f44
    x4: 0x0000000000000000   x5: 0x0000000000000000   x6: 0x0000000000000036   x7: 0x0000000000000001
    x8: 0x000000003bff0000   x9: 0x000000067ffe8008  x10: 0x000000000000000c  x11: 0x00000002c0140008
   x12: 0x000000003bff0000  x13: 0x000000002422a000  x14: 0x0000000024200000  x15: 0x0000000000023800
   x16: 0x00000001c43e0654  x17: 0x000000021eba7698  x18: 0x0000000000000000  x19: 0x000000013e77ac40
   x20: 0x000000013e77ac40  x21: 0x000000013e77ac48  x22: 0x0000000000000945  x23: 0x000000013e77ac00
   x24: 0x000000016d552278  x25: 0x000000000000006f  x26: 0x0000000000000002  x27: 0x0000000000000003
   x28: 0x000000010c6197a7   fp: 0x000000016c522d60   lr: 0x000000010c0f9464
    sp: 0x000000016c522c90   pc: 0x00000001051fe7cc cpsr: 0x20001000
   far: 0x000000067ffe8000  esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
       0x104f60000 -        0x10e5d7fff org.blenderfoundation.blender (3.0.0) <00799098-c74c-38e9-90ce-d7edb0f53c00> /Applications/Blender.app/Contents/MacOS/Blender
       0x115bb8000 -        0x115c17fff dyld (*) <7e92b284-4b90-3b68-b31a-3ddc4c0e8d40> /usr/lib/dyld
       0x1c438c000 -        0x1c43c1fff libsystem_kernel.dylib (*) <c8b3081a-5081-3a99-bbe3-01413de444c6> /usr/lib/system/libsystem_kernel.dylib
       0x1c4207000 -        0x1c424dfff libdispatch.dylib (*) <3a9e9a1e-72b6-3f66-aa17-d955384c1a39> /usr/lib/system/libdispatch.dylib
       0x1c43c2000 -        0x1c43cefff libsystem_pthread.dylib (*) <ed328b18-eeef-3b15-8858-798b19b0c2cd> /usr/lib/system/libsystem_pthread.dylib
       0x1ccd77000 -        0x1ccd9efff com.apple.audio.caulk (1.0) <37a561f9-46f0-37fe-811b-894385645aed> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
       0x1c5d96000 -        0x1c64c4fff com.apple.audio.CoreAudio (5.0) <fb9c653d-bcad-308b-981b-f2c56c8c17c5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
       0x1c428d000 -        0x1c430dfff libsystem_c.dylib (*) <00fc01c7-36bc-3193-86a3-5c03046b45fb> /usr/lib/system/libsystem_c.dylib
       0x1c43dc000 -        0x1c43e3fff libsystem_platform.dylib (*) <ef6555f4-7a8e-3e51-9b40-5381482dee4d> /usr/lib/system/libsystem_platform.dylib
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
       0x1c4410000 -        0x1c4953fff com.apple.CoreFoundation (6.9) <f5ea9592-4ef9-3d35-b23d-5c21283acc52> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x1c6fa7000 -        0x1c7e5afff com.apple.AppKit (6.9) <a8bbc643-113d-310f-96b6-77a973bf2dba> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=2.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.2G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               768K        6
Activity Tracing                   256K        1
CG backing stores                 4032K        4
CG image                          1200K        9
ColorSync                          528K       25
CoreAnimation                      256K       13
CoreGraphics                        32K        2
CoreUI image data                 1056K        8
Foundation                          16K        1
Kernel Alloc Once                   32K        1
MALLOC                           625.6M      114
MALLOC guard page                  192K        9
MALLOC_MEDIUM (reserved)           1.1G       10         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
OpenGL GLSL                        256K        3
STACK GUARD                        480K       30
Stack                             48.4M       31
Stack Guard                         16K        1
VM_ALLOCATE                       40.8M      149
__AUTH                            1907K      182
__AUTH_CONST                      11.1M      340
__DATA                            69.9M      339
__DATA_CONST                      17.7M      354
__DATA_DIRTY                       881K      120
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       625.4M       16
__OBJC_CONST                      1787K      155
__OBJC_RO                         82.0M        1
__OBJC_RW                         3104K        1
__TEXT                           406.6M      370
__UNICODE                          588K        1
dyld private memory               1024K        1
mapped file                      177.3M       27
shared memory                      912K       15
TOTAL                              3.6G     2342
TOTAL, minus reserved VM space     2.1G     2342
Full Report
{"app_name":"Blender","timestamp":"2022-01-28 09:44:17.00 -0500","app_version":"3.0.0","slice_uuid":"00799098-c74c-38e9-90ce-d7edb0f53c00","build_version":"3.0.0 2021-12-03","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.1 (21C52)","incident_id":"632E36AA-4840-435D-9DEB-826B4935DBA7","name":"Blender"}
  "uptime" : 64,
  "procLaunch" : "2022-01-28 09:44:02.7230 -0500",
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro18,2",
  "procStartAbsTime" : 1225437207,
  "coalitionID" : 727,
  "osVersion" : {
    "train" : "macOS 12.1",
    "build" : "21C52",
    "releaseType" : "User"
  "captureTime" : "2022-01-28 09:44:15.9016 -0500",
  "incident" : "632E36AA-4840-435D-9DEB-826B4935DBA7",
  "bug_type" : "309",
  "pid" : 601,
  "procExitAbsTime" : 1541328352,
  "translated" : false,
  "cpuType" : "ARM-64",
  "procName" : "Blender",
  "procPath" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender",
  "bundleInfo" : {"CFBundleShortVersionString":"3.0.0","CFBundleVersion":"3.0.0 2021-12-03","CFBundleIdentifier":"org.blenderfoundation.blender"},
  "storeInfo" : {"deviceIdentifierForVendor":"5532B2B3-82FE-5811-A1A0-3A97645D103A","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "org.blenderfoundation.blender",
  "crashReporterKey" : "433695DF-1121-C958-75E4-A0D5EAF921ED",
  "sip" : "enabled",
  "vmRegionInfo" : "0x67ffe8000 is not in any region.  Bytes after previous region: 15971811329  Bytes before following region: 39728545792\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      MALLOC_MEDIUM (reserved)    2c7800000-2c8000000    [ 8192K] rw-\/rwx SM=NUL  ...(unallocated)\n--->  GAP OF 0xcf8000000 BYTES\n      commpage (reserved)         fc0000000-1000000000   [  1.0G] ---\/--- SM=NUL  ...(unallocated)",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000001, 0x000000067ffe8000","rawCodes":[1,27917189120],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x000000067ffe8000"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":601},
  "vmregioninfo" : "0x67ffe8000 is not in any region.  Bytes after previous region: 15971811329  Bytes before following region: 39728545792\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      MALLOC_MEDIUM (reserved)    2c7800000-2c8000000    [ 8192K] rw-\/rwx SM=NUL  ...(unallocated)\n--->  GAP OF 0xcf8000000 BYTES\n      commpage (reserved)         fc0000000-1000000000   [  1.0G] ---\/--- SM=NUL  ...(unallocated)",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 20,
  "threads" : [{"id":6459,"queue":"com.apple.main-thread","frames":[{"imageOffset":2795936,"symbol":"loop_split_worker_do(LoopSplitTaskDataCommon*, LoopSplitTaskData*, BLI_Stack*)","symbolLocation":260,"imageIndex":0},{"imageOffset":2791740,"symbol":"loop_split_generator(TaskPool*, LoopSplitTaskDataCommon*)","symbolLocation":304,"imageIndex":0},{"imageOffset":2791740,"symbol":"loop_split_generator(TaskPool*, LoopSplitTaskDataCommon*)","symbolLocation":304,"imageIndex":0},{"imageOffset":2791040,"symbol":"BKE_mesh_normals_loop_split","symbolLocation":412,"imageIndex":0},{"imageOffset":2715804,"symbol":"BKE_mesh_calc_normals_split_ex","symbolLocation":372,"imageIndex":0},{"imageOffset":1395636,"symbol":"mesh_calc_modifier_final_normals(Mesh const*, CustomData_MeshMasks const*, bool, Mesh*)","symbolLocation":160,"imageIndex":0},{"imageOffset":1395828,"symbol":"tbb::interface7::internal::delegated_function<mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**)::$_0 const, void>::operator()() const","symbolLocation":68,"imageIndex":0},{"imageOffset":5723556,"symbol":"tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long)","symbolLocation":92,"imageIndex":0},{"imageOffset":1390060,"symbol":"mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**)","symbolLocation":1116,"imageIndex":0},{"imageOffset":1388268,"symbol":"mesh_build_data(Depsgraph*, Scene*, Object*, CustomData_MeshMasks const*, bool)","symbolLocation":144,"imageIndex":0},{"imageOffset":1385404,"symbol":"makeDerivedMesh","symbolLocation":124,"imageIndex":0},{"imageOffset":3131124,"symbol":"BKE_object_handle_data_update","symbolLocation":884,"imageIndex":0},{"imageOffset":3132012,"symbol":"BKE_object_eval_uber_data","symbolLocation":64,"imageIndex":0},{"imageOffset":6879080,"symbol":"blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*)","symbolLocation":140,"imageIndex":0},{"imageOffset":119111612,"symbol":"tbb::internal::function_task<Task>::execute()","symbolLocation":24,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":26215340,"symbol":"tbb::internal::task_group_base::wait()","symbolLocation":40,"imageIndex":0},{"imageOffset":119110652,"symbol":"BLI_task_pool_work_and_wait","symbolLocation":392,"imageIndex":0},{"imageOffset":6878556,"symbol":"blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph*)","symbolLocation":572,"imageIndex":0},{"imageOffset":3390276,"symbol":"scene_graph_update_tagged","symbolLocation":360,"imageIndex":0},{"imageOffset":5818012,"symbol":"wm_event_do_depsgraph","symbolLocation":188,"imageIndex":0},{"imageOffset":5854984,"symbol":"wm_file_read_post","symbolLocation":316,"imageIndex":0},{"imageOffset":5852136,"symbol":"WM_file_read","symbolLocation":640,"imageIndex":0},{"imageOffset":5873392,"symbol":"wm_open_mainfile__open","symbolLocation":308,"imageIndex":0},{"imageOffset":5832612,"symbol":"wm_handler_fileselect_do","symbolLocation":512,"imageIndex":0},{"imageOffset":5848428,"symbol":"wm_handlers_do_intern","symbolLocation":3192,"imageIndex":0},{"imageOffset":5830488,"symbol":"wm_handlers_do","symbolLocation":64,"imageIndex":0},{"imageOffset":5827836,"symbol":"wm_event_do_handlers","symbolLocation":1300,"imageIndex":0},{"imageOffset":5798148,"symbol":"WM_main","symbolLocation":36,"imageIndex":0},{"imageOffset":1324916,"symbol":"main","symbolLocation":924,"imageIndex":0},{"imageOffset":20724,"symbol":"start","symbolLocation":520,"imageIndex":1}]},{"id":6465,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6466,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6467,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6468,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6469,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6470,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6471,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6472,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6473,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6474,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":3},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":3},{"imageOffset":94205836,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":0},{"imageOffset":94200724,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6475,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":6476,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":6477,"name":"AMCP Logging Spool","frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":129196,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":28,"imageIndex":5},{"imageOffset":9820,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":56,"imageIndex":5},{"imageOffset":8828,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":96,"imageIndex":5},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6492,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":6531,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":6563,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":6484,"symbol":"mach_msg_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":7424,"symbol":"mach_msg","symbolLocation":76,"imageIndex":2},{"imageOffset":3383024,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":104,"imageIndex":6},{"imageOffset":1871364,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3360,"imageIndex":6},{"imageOffset":1866464,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":100,"imageIndex":6},{"imageOffset":3748896,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":88,"imageIndex":6},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6566,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":6567,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":6584,"frames":[{"imageOffset":228472,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":608,"imageIndex":1},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":1},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":1},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":7},{"imageOffset":119098620,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":0},{"imageOffset":1339936,"symbol":"sig_handle_crash","symbolLocation":356,"imageIndex":0},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":8},{"imageOffset":119116900,"symbol":"void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":576,"imageIndex":0},{"imageOffset":119115968,"symbol":"void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":152,"imageIndex":0},{"imageOffset":119115796,"symbol":"tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute()","symbolLocation":116,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5714476,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":0},{"imageOffset":5751524,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":0},{"imageOffset":5756380,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":0},{"imageOffset":5756080,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"triggered":true,"id":6585,"threadState":{"x":[{"value":11812302660},{"value":19864649736},{"value":11811618824},{"value":11812499268},{"value":0},{"value":0},{"value":54},{"value":1},{"value":1006567424},{"value":27917189128},{"value":12},{"value":11812470792},{"value":1006567424},{"value":606248960},{"value":606076928},{"value":145408},{"value":7587366484,"symbolLocation":0,"symbol":"OSMemoryBarrier"},{"value":9105471128},{"value":0},{"value":5342997568},{"value":5342997568},{"value":5342997576},{"value":2373},{"value":5342997504},{"value":6129263224},{"value":111},{"value":2},{"value":3},{"value":4502689703,"symbolLocation":32,"symbol":"typeinfo name for rml::versioned_object"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4497314916},"cpsr":{"value":536875008},"fp":{"value":6112292192},"sp":{"value":6112291984},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4380944332,"matchesCrashFrame":1},"far":{"value":27917189120}},"frames":[{"imageOffset":2746316,"symbol":"BKE_mesh_calc_poly_normal","symbolLocation":16,"imageIndex":0},{"imageOffset":119116900,"symbol":"void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":576,"imageIndex":0},{"imageOffset":119115968,"symbol":"void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":152,"imageIndex":0},{"imageOffset":119115796,"symbol":"tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute()","symbolLocation":116,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5714476,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":0},{"imageOffset":5751524,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":0},{"imageOffset":5756380,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":0},{"imageOffset":5756080,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6586,"frames":[{"imageOffset":228496,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":632,"imageIndex":1},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":1},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":1},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":7},{"imageOffset":119098620,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":0},{"imageOffset":1339936,"symbol":"sig_handle_crash","symbolLocation":356,"imageIndex":0},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":8},{"imageOffset":5384089096,"imageIndex":9},{"imageOffset":2782960,"symbol":"BKE_mesh_mirror_apply_mirror_on_axis_for_modifier","symbolLocation":3076,"imageIndex":0},{"imageOffset":7995600,"symbol":"modifyMesh","symbolLocation":192,"imageIndex":0},{"imageOffset":1391280,"symbol":"mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**)","symbolLocation":2336,"imageIndex":0},{"imageOffset":1388268,"symbol":"mesh_build_data(Depsgraph*, Scene*, Object*, CustomData_MeshMasks const*, bool)","symbolLocation":144,"imageIndex":0},{"imageOffset":1385404,"symbol":"makeDerivedMesh","symbolLocation":124,"imageIndex":0},{"imageOffset":3131124,"symbol":"BKE_object_handle_data_update","symbolLocation":884,"imageIndex":0},{"imageOffset":3132012,"symbol":"BKE_object_eval_uber_data","symbolLocation":64,"imageIndex":0},{"imageOffset":6879080,"symbol":"blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*)","symbolLocation":140,"imageIndex":0},{"imageOffset":119111612,"symbol":"tbb::internal::function_task<Task>::execute()","symbolLocation":24,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5714476,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":0},{"imageOffset":5751524,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":0},{"imageOffset":5756380,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":0},{"imageOffset":5756080,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6587,"frames":[{"imageOffset":228488,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":624,"imageIndex":1},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":1},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":1},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":7},{"imageOffset":119098620,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":0},{"imageOffset":1339936,"symbol":"sig_handle_crash","symbolLocation":356,"imageIndex":0},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":8},{"imageOffset":119116900,"symbol":"void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":576,"imageIndex":0},{"imageOffset":119115968,"symbol":"void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":152,"imageIndex":0},{"imageOffset":119115796,"symbol":"tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute()","symbolLocation":116,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5714476,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":0},{"imageOffset":5751524,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":0},{"imageOffset":5756380,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":0},{"imageOffset":5756080,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6588,"frames":[{"imageOffset":32000,"symbol":"__sigaction","symbolLocation":8,"imageIndex":2},{"imageOffset":14288,"symbol":"__platform_sigaction","symbolLocation":108,"imageIndex":8},{"imageOffset":148868,"symbol":"signal__","symbolLocation":80,"imageIndex":7},{"imageOffset":1340040,"symbol":"sig_handle_crash","symbolLocation":460,"imageIndex":0},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":8},{"imageOffset":11174182408,"imageIndex":9},{"imageOffset":2782960,"symbol":"BKE_mesh_mirror_apply_mirror_on_axis_for_modifier","symbolLocation":3076,"imageIndex":0},{"imageOffset":7995600,"symbol":"modifyMesh","symbolLocation":192,"imageIndex":0},{"imageOffset":1391280,"symbol":"mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**)","symbolLocation":2336,"imageIndex":0},{"imageOffset":1388268,"symbol":"mesh_build_data(Depsgraph*, Scene*, Object*, CustomData_MeshMasks const*, bool)","symbolLocation":144,"imageIndex":0},{"imageOffset":1385404,"symbol":"makeDerivedMesh","symbolLocation":124,"imageIndex":0},{"imageOffset":3131124,"symbol":"BKE_object_handle_data_update","symbolLocation":884,"imageIndex":0},{"imageOffset":3132012,"symbol":"BKE_object_eval_uber_data","symbolLocation":64,"imageIndex":0},{"imageOffset":6879080,"symbol":"blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*)","symbolLocation":140,"imageIndex":0},{"imageOffset":119111612,"symbol":"tbb::internal::function_task<Task>::execute()","symbolLocation":24,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5714476,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":0},{"imageOffset":5751524,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":0},{"imageOffset":5756380,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":0},{"imageOffset":5756080,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6589,"frames":[{"imageOffset":228496,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":632,"imageIndex":1},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":1},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":1},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":7},{"imageOffset":119098620,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":0},{"imageOffset":1339936,"symbol":"sig_handle_crash","symbolLocation":356,"imageIndex":0},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":8},{"imageOffset":119116900,"symbol":"void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":576,"imageIndex":0},{"imageOffset":119115968,"symbol":"void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":152,"imageIndex":0},{"imageOffset":119115796,"symbol":"tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute()","symbolLocation":116,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5768308,"symbol":"tbb::internal::generic_scheduler::spawn_root_and_wait(tbb::task&, tbb::task*&)","symbolLocation":224,"imageIndex":0},{"imageOffset":119115092,"symbol":"tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::run(tbb::blocked_range<int> const&, RangeTask const&, tbb::auto_partitioner const&)","symbolLocation":164,"imageIndex":0},{"imageOffset":119111908,"symbol":"BLI_task_parallel_range","symbolLocation":284,"imageIndex":0},{"imageOffset":2785748,"symbol":"BKE_mesh_ensure_normals_for_display","symbolLocation":444,"imageIndex":0},{"imageOffset":1395684,"symbol":"mesh_calc_modifier_final_normals(Mesh const*, CustomData_MeshMasks const*, bool, Mesh*)","symbolLocation":208,"imageIndex":0},{"imageOffset":1395828,"symbol":"tbb::interface7::internal::delegated_function<mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**)::$_0 const, void>::operator()() const","symbolLocation":68,"imageIndex":0},{"imageOffset":5723556,"symbol":"tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long)","symbolLocation":92,"imageIndex":0},{"imageOffset":1390060,"symbol":"mesh_calc_modifiers(Depsgraph*, Scene*, Object*, bool, bool, CustomData_MeshMasks const*, int, bool, bool, Mesh**, Mesh**, GeometrySet**)","symbolLocation":1116,"imageIndex":0},{"imageOffset":1388268,"symbol":"mesh_build_data(Depsgraph*, Scene*, Object*, CustomData_MeshMasks const*, bool)","symbolLocation":144,"imageIndex":0},{"imageOffset":1385404,"symbol":"makeDerivedMesh","symbolLocation":124,"imageIndex":0},{"imageOffset":3131124,"symbol":"BKE_object_handle_data_update","symbolLocation":884,"imageIndex":0},{"imageOffset":3132012,"symbol":"BKE_object_eval_uber_data","symbolLocation":64,"imageIndex":0},{"imageOffset":6879080,"symbol":"blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*)","symbolLocation":140,"imageIndex":0},{"imageOffset":119111612,"symbol":"tbb::internal::function_task<Task>::execute()","symbolLocation":24,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5714476,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":0},{"imageOffset":5751524,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":0},{"imageOffset":5756380,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":0},{"imageOffset":5756080,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6590,"frames":[{"imageOffset":228192,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":328,"imageIndex":1},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":1},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":1},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":7},{"imageOffset":119098620,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":0},{"imageOffset":1339936,"symbol":"sig_handle_crash","symbolLocation":356,"imageIndex":0},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":8},{"imageOffset":119116900,"symbol":"void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":576,"imageIndex":0},{"imageOffset":119115968,"symbol":"void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":152,"imageIndex":0},{"imageOffset":119115796,"symbol":"tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute()","symbolLocation":116,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5714476,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":0},{"imageOffset":5751524,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":0},{"imageOffset":5756380,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":0},{"imageOffset":5756080,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6591,"frames":[{"imageOffset":228272,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":408,"imageIndex":1},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":1},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":1},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":7},{"imageOffset":119098620,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":0},{"imageOffset":1339936,"symbol":"sig_handle_crash","symbolLocation":356,"imageIndex":0},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":8},{"imageOffset":119116900,"symbol":"void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":576,"imageIndex":0},{"imageOffset":119115968,"symbol":"void tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>, tbb::blocked_range<int> >(tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>&, tbb::blocked_range<int>&)","symbolLocation":152,"imageIndex":0},{"imageOffset":119115796,"symbol":"tbb::interface9::internal::start_for<tbb::blocked_range<int>, RangeTask, tbb::auto_partitioner const>::execute()","symbolLocation":116,"imageIndex":0},{"imageOffset":5780700,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":0},{"imageOffset":5778316,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":0},{"imageOffset":5714476,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":0},{"imageOffset":5751524,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":0},{"imageOffset":5756380,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":0},{"imageOffset":5756080,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6609,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6484,"symbol":"mach_msg_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":7424,"symbol":"mach_msg","symbolLocation":76,"imageIndex":2},{"imageOffset":544472,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":372,"imageIndex":10},{"imageOffset":537488,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":10},{"imageOffset":534324,"symbol":"CFRunLoopRunSpecific","symbolLocation":600,"imageIndex":10},{"imageOffset":1764496,"symbol":"_NSEventThread","symbolLocation":196,"imageIndex":11},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":4},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":4}]},{"id":6925,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":6926,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4378198016,
    "CFBundleShortVersionString" : "3.0.0",
    "CFBundleIdentifier" : "org.blenderfoundation.blender",
    "size" : 157777920,
    "uuid" : "00799098-c74c-38e9-90ce-d7edb0f53c00",
    "path" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender",
    "name" : "Blender",
    "CFBundleVersion" : "3.0.0 2021-12-03"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4659576832,
    "size" : 393216,
    "uuid" : "7e92b284-4b90-3b68-b31a-3ddc4c0e8d40",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7587020800,
    "size" : 221184,
    "uuid" : "c8b3081a-5081-3a99-bbe3-01413de444c6",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7585427456,
    "size" : 290816,
    "uuid" : "3a9e9a1e-72b6-3f66-aa17-d955384c1a39",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7587241984,
    "size" : 53248,
    "uuid" : "ed328b18-eeef-3b15-8858-798b19b0c2cd",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7731638272,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 163840,
    "uuid" : "37a561f9-46f0-37fe-811b-894385645aed",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7614324736,
    "CFBundleShortVersionString" : "5.0",
    "CFBundleIdentifier" : "com.apple.audio.CoreAudio",
    "size" : 7532544,
    "uuid" : "fb9c653d-bcad-308b-981b-f2c56c8c17c5",
    "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
    "name" : "CoreAudio",
    "CFBundleVersion" : "5.0"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7585976320,
    "size" : 528384,
    "uuid" : "00fc01c7-36bc-3193-86a3-5c03046b45fb",
    "path" : "\/usr\/lib\/system\/libsystem_c.dylib",
    "name" : "libsystem_c.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7587348480,
    "size" : 32768,
    "uuid" : "ef6555f4-7a8e-3e51-9b40-5381482dee4d",
    "path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
    "name" : "libsystem_platform.dylib"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7587561472,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5521408,
    "uuid" : "f5ea9592-4ef9-3d35-b23d-5c21283acc52",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1856.105"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7633268736,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15417344,
    "uuid" : "a8bbc643-113d-310f-96b6-77a973bf2dba",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2113.20.111"
  "sharedCache" : {
  "base" : 7584071680,
  "size" : 3089596416,
  "uuid" : "66c33c62-48a9-31e5-b8b5-7a71c9760d07"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=2.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.2G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               768K        6 \nActivity Tracing                   256K        1 \nCG backing stores                 4032K        4 \nCG image                          1200K        9 \nColorSync                          528K       25 \nCoreAnimation                      256K       13 \nCoreGraphics                        32K        2 \nCoreUI image data                 1056K        8 \nFoundation                          16K        1 \nKernel Alloc Once                   32K        1 \nMALLOC                           625.6M      114 \nMALLOC guard page                  192K        9 \nMALLOC_MEDIUM (reserved)           1.1G       10         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nOpenGL GLSL                        256K        3 \nSTACK GUARD                        480K       30 \nStack                             48.4M       31 \nStack Guard                         16K        1 \nVM_ALLOCATE                       40.8M      149 \n__AUTH                            1907K      182 \n__AUTH_CONST                      11.1M      340 \n__DATA                            69.9M      339 \n__DATA_CONST                      17.7M      354 \n__DATA_DIRTY                       881K      120 \n__FONT_DATA                          4K        1 \n__GLSLBUILTINS                    5176K        1 \n__LINKEDIT                       625.4M       16 \n__OBJC_CONST                      1787K      155 \n__OBJC_RO                         82.0M        1 \n__OBJC_RW                         3104K        1 \n__TEXT                           406.6M      370 \n__UNICODE                          588K        1 \ndyld private memory               1024K        1 \nmapped file                      177.3M       27 \nshared memory                      912K       15 \n===========                     =======  ======= \nTOTAL                              3.6G     2342 \nTOTAL, minus reserved VM space     2.1G     2342 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "607844aa04477260f58a8077",
      "factorPackIds" : {
        "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"
      "deploymentId" : 240000066
      "rolloutId" : "602ad4dac86151000cf27e46",
      "factorPackIds" : {
        "SIRI_DICTATION_ASSETS" : "61a80a438feb033580c2778b"
      "deploymentId" : 240000290
      "rolloutId" : "60da5e84ab0ca017dace9abf",
      "factorPackIds" : {
      "deploymentId" : 240000008
      "rolloutId" : "5ffde50ce2aacd000d47a95f",
      "factorPackIds" : {
      "deploymentId" : 240000090
      "rolloutId" : "5fc94383418129005b4e9ae0",
      "factorPackIds" : {
      "deploymentId" : 240000196
      "rolloutId" : "601d9415f79519000ccd4b69",
      "factorPackIds" : {
        "SIRI_TEXT_TO_SPEECH" : "61c11dcd2cb6041dc630dc63"
      "deploymentId" : 240000357
  "experiments" : [
Model: MacBookPro18,2, BootROM 7429.61.2, proc 10:8:2 processors, 64 GB, SMC
Graphics: Apple M1 Max, Apple M1 Max, Built-In
Display: Color LCD, 3456 x 2234 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5
AirPort: Wi-Fi, wl0: Oct 25 2021 22:17:59 version 20.10.853.26.8.7.107 FWID 01-417a4935
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: Rugged USB-C
Thunderbolt Bus: MacBook Pro, Apple Inc.
Unfortunately your file is quite corrupted.
A lot of Objects in them have weird loop values.
We can "fix" this file if you really need it.
But unfortunately unless there are clear instructions on how to reproduce it from scratch we cannot debug this any further.
Things that may cause mesh corruption: Importers, development versions of Blender, modeling tools.
