sculpt mode: invert visible hides all faces with Multires modifier
Confirmed, NormalPublicKNOWN ISSUE
Graphics card: NVIDIA GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-01-31 23:00, hash: rBf420118335e4
Invert visible face sets hides all faces with Multires modifier.
Operator is expected to only hide visible faces (and unhides hidden faces)
  • Open .blend file
  • Use box hide brush to hide vertices
  • Face setsInvert Visible Face Sets
Test File:
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Feb 2 2022, 6:19 AM
Hi, thanks for the report. Description is not clear to me.
You mean all faces will be hidden when operator Invert Visible is used? I can confirm in that case.
That is, after hiding the mesh, it will be hidden when running the inversion operation. If there is no multires modifier, it is normal inversion implicit
Pratik Borhade (PratikPB2123) renamed this task from Multires modifier in sculpt mode use "box hide" ops error to sculpt mode: invert visible hides all faces with Multires modifier.Feb 2 2022, 7:31 AM
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Confirmed.
Pratik Borhade (PratikPB2123) updated the task description. (Show Details)
Julien Kaspar (JulienKaspar) changed the subtype of this task from "Report" to "Known Issue".
The hiding gesture tools were never properly integrated into the new face set visibility state in multires. I'd mark this as a known issue for now.
Further multires improvements should fix this.
