Crash, working with particle systems
Operating system: MacOS 12.1 Monterey
Graphics card: AMD Radeon RX Vega 56 8 GB
Broken: (example: 3.1 Beta (latest/greatest as of Feb 3, 2022)
"Boom!" happens when I try weight-paint something, using particle system. Problem is that it does not happen all the time, so reproducing is tough.
1
2-------------------------------------
3Translated Report (Full Report Below)
4-------------------------------------
5
6Process: Blender [2869]
7Path: /Applications/Blender/Blender.app/Contents/MacOS/Blender
8Identifier: org.blenderfoundation.blender
9Version: 3.1.0 (3.1.0 2022-01-31)
10Code Type: X86-64 (Native)
11Parent Process: launchd [1]
12User ID: 501
13
14Date/Time: 2022-02-03 22:04:35.9928 +0100
15OS Version: macOS 12.1 (21C52)
16Report Version: 12
17Bridge OS Version: 6.1 (19P647)
18Anonymous UUID: 229ABBC2-C318-7915-FA97-7BBEFE9A75FB
19
20
21Time Awake Since Boot: 37000 seconds
22
23System Integrity Protection: enabled
24
25Crashed Thread: 0 Dispatch queue: com.apple.main-thread
26
27Exception Type: EXC_BAD_ACCESS (SIGSEGV)
28Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000c8
29Exception Codes: 0x0000000000000001, 0x00000000000000c8
30Exception Note: EXC_CORPSE_NOTIFY
31
32Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
33Terminating Process: exc handler [2869]
34
35VM Region Info: 0xc8 is not in any region. Bytes before following region: 4449857336
36 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
37 UNUSED SPACE AT START
38--->
39 __TEXT 1093b7000-115cef000 [201.2M] r-x/r-x SM=COW ...MacOS/Blender
40
41ID Vend/Dev
428938 687f1002
43Seconds Ago ID Type
44 37000.0 8938 Attach
45
46
47Kernel Triage:
48VM - Fault hit memory shortage
49VM - Fault hit memory shortage
50VM - Fault hit memory shortage
51VM - Fault hit memory shortage
52VM - Fault hit memory shortage
53
54
55Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
560 GLEngine 0x7ffa2fd16da5 gleUpdateCtxDirtyStateForBufStampChange + 340
571 GLEngine 0x7ffa2fd17d21 gleBindBufferObject + 3249
582 GLEngine 0x7ffa2fc7210b glBindBuffer_Exec + 128
593 Blender 0x111e8f876 blender::gpu::GLUniformBuf::update(void const*) + 118
604 Blender 0x109c6e365 DRW_globals_update + 2629
615 Blender 0x109c72f39 DRW_draw_render_loop_ex + 569
626 Blender 0x10a7ae38a view3d_main_region_draw + 138
637 Blender 0x10a0708c1 ED_region_do_draw + 337
648 Blender 0x109af73ed wm_draw_update + 1757
659 Blender 0x109af4920 WM_main + 48
6610 Blender 0x109533fc9 main + 873
6711 dyld 0x12a5454fe start + 462
68
69Thread 1:
700 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
711 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
722 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
733 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
744 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
755 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
766 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
77
78Thread 2:
790 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
801 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
812 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
823 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
834 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
845 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
856 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
86
87Thread 3:
880 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
891 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
902 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
913 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
924 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
935 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
946 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
95
96Thread 4:
970 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
981 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
992 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
1003 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
1014 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
1025 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1036 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
104
105Thread 5:
1060 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1071 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
1082 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
1093 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
1104 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
1115 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1126 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
113
114Thread 6:
1150 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1161 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
1172 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
1183 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
1194 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
1205 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1216 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
122
123Thread 7:
1240 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1251 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
1262 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
1273 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
1284 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
1295 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1306 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
131
132Thread 8:
1330 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1341 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
1352 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
1363 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
1374 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
1385 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1396 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
140
141Thread 9:
1420 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1431 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
1442 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
1453 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
1464 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
1475 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1486 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
149
150Thread 10:
1510 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1521 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
1532 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
1543 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
1554 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
1565 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1576 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
158
159Thread 11:
1600 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1611 libdispatch.dylib 0x7ff817b95178 _dispatch_sema4_wait + 16
1622 libdispatch.dylib 0x7ff817b95647 _dispatch_semaphore_wait_slow + 98
1633 Blender 0x11189dc4f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
1644 Blender 0x11189c6de void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
1655 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1666 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
167
168Thread 12:: AMCP Logging Spool
1690 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1701 caulk 0x7ff8207cf1c0 caulk::mach::semaphore::wait_or_error() + 16
1712 caulk 0x7ff8207b608a caulk::concurrent::details::worker_thread::run() + 36
1723 caulk 0x7ff8207b5d4e void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41
1734 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1745 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
175
176Thread 13:: com.apple.audio.IOThread.client
1770 libsystem_kernel.dylib 0x7ff817d0eaba mach_msg_trap + 10
1781 libsystem_kernel.dylib 0x7ff817d0ee2b mach_msg + 59
1792 CoreAudio 0x7ff81999295b HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
1803 CoreAudio 0x7ff8198210ff HALC_ProxyIOContext::IOWorkLoop() + 3937
1814 CoreAudio 0x7ff81981fbc1 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 63
1825 CoreAudio 0x7ff8199e876c HALB_IOThread::Entry(void*) + 72
1836 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1847 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
185
186Thread 14:
1870 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1881 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
1892 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
1903 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1914 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
192
193Thread 15:
1940 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
1951 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
1962 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
1973 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
1984 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
199
200Thread 16:
2010 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2021 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2032 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2043 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2054 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
206
207Thread 17:
2080 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2091 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2102 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2113 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2124 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
213
214Thread 18:
2150 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2161 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2172 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2183 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2194 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
220
221Thread 19:
2220 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2231 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2242 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2253 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2264 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
227
228Thread 20:
2290 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2301 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2312 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2323 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2334 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
234
235Thread 21:
2360 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2371 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2382 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2393 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2404 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
241
242Thread 22:
2430 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2441 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2452 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2463 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2474 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
248
249Thread 23:
2500 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2511 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2522 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2533 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2544 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
255
256Thread 24:
2570 libsystem_kernel.dylib 0x7ff817d0eaf6 semaphore_wait_trap + 10
2581 Blender 0x109aeb1f8 tbb::internal::rml::private_worker::run() + 344
2592 Blender 0x109aeb099 tbb::internal::rml::private_worker::thread_routine(void*) + 9
2603 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
2614 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
262
263Thread 25:
2640 libsystem_kernel.dylib 0x7ff817d15196 __accept + 10
2651 _socket.cpython-310-darwin.so 0x123d46388 sock_accept_impl + 24
2662 _socket.cpython-310-darwin.so 0x123d467e2 sock_call_ex + 402
2673 _socket.cpython-310-darwin.so 0x123d44080 sock_accept + 144
2684 Blender 0x111f60247 method_vectorcall_NOARGS + 135
2695 Blender 0x11204b5df call_function + 431
2706 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501
2717 Blender 0x112040d01 _PyEval_Vector + 145
2728 Blender 0x11204b5df call_function + 431
2739 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501
27410 Blender 0x112040d01 _PyEval_Vector + 145
27511 Blender 0x11204b5df call_function + 431
27612 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501
27713 Blender 0x112040d01 _PyEval_Vector + 145
27814 Blender 0x11204b5df call_function + 431
27915 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501
28016 Blender 0x112040d01 _PyEval_Vector + 145
28117 Blender 0x111f590bf method_vectorcall + 367
28218 Blender 0x1120f4da6 thread_run + 70
28319 Blender 0x1120a5229 pythread_wrapper + 25
28420 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
28521 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
286
287Thread 26:
2880 libsystem_kernel.dylib 0x7ff817d16e4a __select + 10
2891 Blender 0x1120f330c time_sleep + 140
2902 Blender 0x111f9ce85 cfunction_vectorcall_O + 277
2913 Blender 0x11204b5df call_function + 431
2924 Blender 0x11204857a _PyEval_EvalFrameDefault + 30538
2935 Blender 0x112040d01 _PyEval_Vector + 145
2946 Blender 0x11204b5df call_function + 431
2957 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501
2968 Blender 0x112040d01 _PyEval_Vector + 145
2979 Blender 0x11204b5df call_function + 431
29810 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501
29911 Blender 0x112040d01 _PyEval_Vector + 145
30012 Blender 0x111f590bf method_vectorcall + 367
30113 Blender 0x1120f4da6 thread_run + 70
30214 Blender 0x1120a5229 pythread_wrapper + 25
30315 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
30416 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
305
306Thread 27:: com.apple.NSEventThread
3070 libsystem_kernel.dylib 0x7ff817d0eaba mach_msg_trap + 10
3081 libsystem_kernel.dylib 0x7ff817d0ee2b mach_msg + 59
3092 CoreFoundation 0x7ff817e12af2 __CFRunLoopServiceMachPort + 319
3103 CoreFoundation 0x7ff817e111cb __CFRunLoopRun + 1325
3114 CoreFoundation 0x7ff817e105dd CFRunLoopRunSpecific + 563
3125 AppKit 0x7ff81a9add98 _NSEventThread + 132
3136 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
3147 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
315
316Thread 28:
3170 libsystem_kernel.dylib 0x7ff817d16e4a __select + 10
3181 Blender 0x1120f330c time_sleep + 140
3192 Blender 0x111f9ce85 cfunction_vectorcall_O + 277
3203 Blender 0x11204b5df call_function + 431
3214 Blender 0x11204857a _PyEval_EvalFrameDefault + 30538
3225 Blender 0x112040d01 _PyEval_Vector + 145
3236 Blender 0x11204b5df call_function + 431
3247 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501
3258 Blender 0x112040d01 _PyEval_Vector + 145
3269 Blender 0x11204b5df call_function + 431
32710 Blender 0x112048555 _PyEval_EvalFrameDefault + 30501
32811 Blender 0x112040d01 _PyEval_Vector + 145
32912 Blender 0x111f590bf method_vectorcall + 367
33013 Blender 0x1120f4da6 thread_run + 70
33114 Blender 0x1120a5229 pythread_wrapper + 25
33215 libsystem_pthread.dylib 0x7ff817d4b4f4 _pthread_start + 125
33316 libsystem_pthread.dylib 0x7ff817d4700f thread_start + 15
334
335Thread 29:
3360 libsystem_pthread.dylib 0x7ff817d46fec start_wqthread + 0
337
338Thread 30:
3390 libsystem_pthread.dylib 0x7ff817d46fec start_wqthread + 0
340
341Thread 31:
3420 libsystem_pthread.dylib 0x7ff817d46fec start_wqthread + 0
343
344Thread 32:
3450 libsystem_pthread.dylib 0x7ff817d46fec start_wqthread + 0
346
347
348Thread 0 crashed with X86 Thread State (64-bit):
349 rax: 0x00007fd37178f520 rbx: 0x00007fd4df74e000 rcx: 0x0000000000000000 rdx: 0x00000000fff9ae96
350 rdi: 0x00000000fffff676 rsi: 0x0000000000000050 rbp: 0x00007ff7b6b47040 rsp: 0x00007ff7b6b47020
351 r8: 0x0000000000000000 r9: 0x00007fd4da0e2ab0 r10: 0x00000000000007fb r11: 0x00000000055196d8
352 r12: 0x0000000000000001 r13: 0x00007fd4df74e000 r14: 0x0000000000000001 r15: 0x0000000000000009
353 rip: 0x00007ffa2fd16da5 rfl: 0x0000000000010206 cr2: 0x00000000000000c8
354
355Logical CPU: 2
356Error Code: 0x00000004 (no mapping for user data read)
357Trap Number: 14
358
359Thread 0 instruction stream:
360 00 85 ff 7f 0a 48 ff c6-48 39 f1 75 df eb 1f 80 .....H..H9.u....
361 88 a0 1a 00 00 10 80 8b-ff 05 00 00 30 c7 83 bc ............0...
362 ae 00 00 00 00 00 00 80-8b 07 06 00 00 10 4c 8b ..............L.
363 b3 88 8d 00 00 4d 85 f6-0f 84 84 00 00 00 45 31 .....M........E1
364 ff 41 bc 01 00 00 00 41-f6 c6 01 74 6d 49 6b c7 .A.....A...tmIk.
365 58 48 8b 84 03 08 61 00-00 48 8b 88 38 02 00 00 XH....a..H..8...
366 [8b]89 c8 00 00 00 2b 8b-2c b6 00 00 85 c9 7e 4a ......+.,.....~J <==
367 48 8d 70 28 0f b6 8b a1-c6 00 00 85 c9 74 1f 41 H.p(.........t.A
368 0f 44 cc 48 c1 e1 03 48-8d 0c 49 31 d2 80 8c 10 .D.H...H..I1....
369 9c 00 00 00 08 48 83 c2-18 48 39 d1 75 ef c7 83 .....H...H9.u...
370 bc ae 00 00 00 00 00 00-81 8b 0c 06 00 00 00 20 ...............
371 02 00 48 89 df e8 8c 8a-04 00 49 ff c7 49 d1 ee ..H.......I..I..
372
373Binary Images:
374 0x7ffa2fc29000 - 0x7ffa2fdb7fff GLEngine (*) <7797ea1d-f2d0-3dc7-950b-961dbc8a0b73> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
375 0x1093b7000 - 0x115ceefff org.blenderfoundation.blender (3.1.0) <11ec9ab2-102c-3dcb-87e9-f3f15347e3e8> /Applications/Blender/Blender.app/Contents/MacOS/Blender
376 0x12a540000 - 0x12a5abfff dyld (*) <cef5a27a-d50b-3020-af03-1734b19bc8c5> /usr/lib/dyld
377 0x7ff817d0e000 - 0x7ff817d44fff libsystem_kernel.dylib (*) <5aa1e5be-b5b8-3a02-9885-a8c99e0ca378> /usr/lib/system/libsystem_kernel.dylib
378 0x7ff817b92000 - 0x7ff817bd8fff libdispatch.dylib (*) <c8f7bfb6-4b1a-37cd-a32d-cd5069c916df> /usr/lib/system/libdispatch.dylib
379 0x7ff817d45000 - 0x7ff817d50fff libsystem_pthread.dylib (*) <6c7561b4-4b92-3f45-921e-abe669299844> /usr/lib/system/libsystem_pthread.dylib
380 0x7ff8207b4000 - 0x7ff8207d6fff com.apple.audio.caulk (1.0) <e76d1ab3-89c2-3a93-990b-30827fcf89b0> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
381 0x7ff81966a000 - 0x7ff819d91fff com.apple.audio.CoreAudio (5.0) <33f55d9c-eaef-3fbd-add5-ed3e54925762> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
382 0x123d42000 - 0x123d4ffff _socket.cpython-310-darwin.so (*) <099583aa-a77b-35dd-b414-f30dbc3a62c2> /Applications/Blender/Blender.app/Contents/Resources/3.1/python/lib/python3.10/lib-dynload/_socket.cpython-310-darwin.so
383 0x7ff817d92000 - 0x7ff818294fff com.apple.CoreFoundation (6.9) <eab0e216-2a9e-31ce-9164-fdf3ebcf7bd3> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
384 0x7ff81a801000 - 0x7ff81b68ffff com.apple.AppKit (6.9) <d23b9681-3764-3298-a716-fbb511dd5a7c> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
385 0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
386
387External Modification Summary:
388 Calls made by other processes targeting this process:
389 task_for_pid: 0
390 thread_create: 0
391 thread_set_state: 0
392 Calls made by this process:
393 task_for_pid: 0
394 thread_create: 0
395 thread_set_state: 0
396 Calls made by all processes on this machine:
397 task_for_pid: 0
398 thread_create: 0
399 thread_set_state: 0
400
401VM Region Summary:
402ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)
403Writable regions: Total=6.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.2G(100%)
404
405 VIRTUAL REGION
406REGION TYPE SIZE COUNT (non-coalesced)
407=========== ======= =======
408Accelerate framework 384K 3
409Activity Tracing 256K 1
410CG backing stores 3840K 4
411CG image 696K 18
412ColorSync 224K 25
413CoreAnimation 144K 13
414CoreGraphics 12K 2
415CoreImage 4K 1
416CoreUI image data 1120K 9
417Foundation 16K 1
418Kernel Alloc Once 8K 1
419MALLOC 5.4G 3083
420MALLOC guard page 32K 8
421MALLOC_LARGE (reserved) 256K 1 reserved VM address space (unallocated)
422MALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated)
423OpenGL GLSL 256K 3
424STACK GUARD 132K 33
425Stack 102.8M 34
426Stack Guard 4K 1
427VM_ALLOCATE 396.9M 3940
428VM_ALLOCATE (reserved) 96.0M 1 reserved VM address space (unallocated)
429__DATA 101.7M 422
430__DATA_CONST 17.5M 218
431__DATA_DIRTY 782K 122
432__FONT_DATA 4K 1
433__GLSLBUILTINS 5176K 1
434__LINKEDIT 708.7M 62
435__OBJC_RO 81.8M 1
436__OBJC_RW 3136K 2
437__TEXT 576.7M 431
438__UNICODE 588K 1
439dyld private memory 1152K 3
440mapped file 169.0M 30
441shared memory 784K 17
442=========== ======= =======
443TOTAL 7.8G 8494
444TOTAL, minus reserved VM space 7.5G 8494
445
446
447
448-----------
449Full Report
450-----------
451
452{"app_name":"Blender","timestamp":"2022-02-03 22:04:38.00 +0100","app_version":"3.1.0","slice_uuid":"11ec9ab2-102c-3dcb-87e9-f3f15347e3e8","build_version":"3.1.0 2022-01-31","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.1 (21C52)","incident_id":"2961041B-184F-4C27-81C0-EDB5DE529B51","name":"Blender"}
453{
454 "uptime" : 37000,
455 "procLaunch" : "2022-02-03 21:50:59.4768 +0100",
456 "procRole" : "Foreground",
457 "version" : 2,
458 "userID" : 501,
459 "deployVersion" : 210,
460 "modelCode" : "Macmini8,1",
461 "procStartAbsTime" : 36805586127134,
462 "coalitionID" : 970,
463 "osVersion" : {
464 "train" : "macOS 12.1",
465 "build" : "21C52",
466 "releaseType" : "User"
467 },
468 "captureTime" : "2022-02-03 22:04:35.9928 +0100",
469 "incident" : "2961041B-184F-4C27-81C0-EDB5DE529B51",
470 "bug_type" : "309",
471 "pid" : 2869,
472 "procExitAbsTime" : 37621928999013,
473 "cpuType" : "X86-64",
474 "procName" : "Blender",
475 "procPath" : "\/Applications\/Blender\/Blender.app\/Contents\/MacOS\/Blender",
476 "bundleInfo" : {"CFBundleShortVersionString":"3.1.0","CFBundleVersion":"3.1.0 2022-01-31","CFBundleIdentifier":"org.blenderfoundation.blender"},
477 "storeInfo" : {"deviceIdentifierForVendor":"C36CE686-F8D3-5188-AA46-612C4C28F525","thirdParty":true},
478 "parentProc" : "launchd",
479 "parentPid" : 1,
480 "coalitionName" : "org.blenderfoundation.blender",
481 "crashReporterKey" : "229ABBC2-C318-7915-FA97-7BBEFE9A75FB",
482 "bridgeVersion" : {"build":"19P647","train":"6.1"},
483 "sip" : "enabled",
484 "externalGPUInfo" : "ID Vend\/Dev\n8938 687f1002\nSeconds Ago ID Type\n 37000.0 8938 Attach\n",
485 "vmRegionInfo" : "0xc8 is not in any region. Bytes before following region: 4449857336\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 1093b7000-115cef000 [201.2M] r-x\/r-x SM=COW ...MacOS\/Blender",
486 "isCorpse" : 1,
487 "exception" : {"codes":"0x0000000000000001, 0x00000000000000c8","rawCodes":[1,200],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x00000000000000c8"},
488 "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":2869},
489 "ktriageinfo" : "VM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\n",
490 "vmregioninfo" : "0xc8 is not in any region. Bytes before following region: 4449857336\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 1093b7000-115cef000 [201.2M] r-x\/r-x SM=COW ...MacOS\/Blender",
491 "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
492 "faultingThread" : 0,
493 "threads" : [{"triggered":true,"id":208405,"instructionState":{"instructionStream":{"bytes":[0,133,255,127,10,72,255,198,72,57,241,117,223,235,31,128,136,160,26,0,0,16,128,139,255,5,0,0,48,199,131,188,174,0,0,0,0,0,0,128,139,7,6,0,0,16,76,139,179,136,141,0,0,77,133,246,15,132,132,0,0,0,69,49,255,65,188,1,0,0,0,65,246,198,1,116,109,73,107,199,88,72,139,132,3,8,97,0,0,72,139,136,56,2,0,0,139,137,200,0,0,0,43,139,44,182,0,0,133,201,126,74,72,141,112,40,15,182,139,161,198,0,0,133,201,116,31,65,15,68,204,72,193,225,3,72,141,12,73,49,210,128,140,16,156,0,0,0,8,72,131,194,24,72,57,209,117,239,199,131,188,174,0,0,0,0,0,0,129,139,12,6,0,0,0,32,2,0,72,137,223,232,140,138,4,0,73,255,199,73,209,238],"offset":96}},"threadState":{"r13":{"value":140552258772992},"rax":{"value":140546118579488},"rflags":{"value":66054},"cpu":{"value":2},"r14":{"value":1},"rsi":{"value":80},"r8":{"value":0},"cr2":{"value":200},"rdx":{"value":4294553238},"r10":{"value":2043},"r9":{"value":140552168155824},"r15":{"value":9},"rbx":{"value":140552258772992},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":89233112},"rip":{"value":140712520805797,"matchesCrashFrame":1},"rbp":{"value":140701898928192},"rsp":{"value":140701898928160},"r12":{"value":1},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":4294964854}},"queue":"com.apple.main-thread","frames":[{"imageOffset":974245,"symbol":"gleUpdateCtxDirtyStateForBufStampChange","symbolLocation":340,"imageIndex":0},{"imageOffset":978209,"symbol":"gleBindBufferObject","symbolLocation":3249,"imageIndex":0},{"imageOffset":299275,"symbol":"glBindBuffer_Exec","symbolLocation":128,"imageIndex":0},{"imageOffset":145590390,"symbol":"blender::gpu::GLUniformBuf::update(void const*)","symbolLocation":118,"imageIndex":1},{"imageOffset":9139045,"symbol":"DRW_globals_update","symbolLocation":2629,"imageIndex":1},{"imageOffset":9158457,"symbol":"DRW_draw_render_loop_ex","symbolLocation":569,"imageIndex":1},{"imageOffset":20935562,"symbol":"view3d_main_region_draw","symbolLocation":138,"imageIndex":1},{"imageOffset":13342913,"symbol":"ED_region_do_draw","symbolLocation":337,"imageIndex":1},{"imageOffset":7603181,"symbol":"wm_draw_update","symbolLocation":1757,"imageIndex":1},{"imageOffset":7592224,"symbol":"WM_main","symbolLocation":48,"imageIndex":1},{"imageOffset":1560521,"symbol":"main","symbolLocation":873,"imageIndex":1},{"imageOffset":21758,"symbol":"start","symbolLocation":462,"imageIndex":2}]},{"id":208421,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208422,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208423,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208424,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208425,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208426,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208427,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208428,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208429,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208430,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208431,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":4},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":4},{"imageOffset":139357263,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":1},{"imageOffset":139351774,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208449,"name":"AMCP Logging Spool","frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":111040,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":6},{"imageOffset":8330,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":6},{"imageOffset":7502,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":6},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208474,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":3311963,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":111,"imageIndex":7},{"imageOffset":1798399,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3937,"imageIndex":7},{"imageOffset":1792961,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":63,"imageIndex":7},{"imageOffset":3663724,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":72,"imageIndex":7},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208544,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208545,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208546,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208547,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208548,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208549,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208550,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208551,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208552,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208553,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208554,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7553528,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":1},{"imageOffset":7553177,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208556,"frames":[{"imageOffset":29078,"symbol":"__accept","symbolLocation":10,"imageIndex":3},{"imageOffset":17288,"symbol":"sock_accept_impl","symbolLocation":24,"imageIndex":8},{"imageOffset":18402,"symbol":"sock_call_ex","symbolLocation":402,"imageIndex":8},{"imageOffset":8320,"symbol":"sock_accept","symbolLocation":144,"imageIndex":8},{"imageOffset":146444871,"symbol":"method_vectorcall_NOARGS","symbolLocation":135,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":146415807,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":1},{"imageOffset":148102566,"symbol":"thread_run","symbolLocation":70,"imageIndex":1},{"imageOffset":147776041,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208557,"frames":[{"imageOffset":36426,"symbol":"__select","symbolLocation":10,"imageIndex":3},{"imageOffset":148095756,"symbol":"time_sleep","symbolLocation":140,"imageIndex":1},{"imageOffset":146693765,"symbol":"cfunction_vectorcall_O","symbolLocation":277,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395962,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30538,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":146415807,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":1},{"imageOffset":148102566,"symbol":"thread_run","symbolLocation":70,"imageIndex":1},{"imageOffset":147776041,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208615,"name":"com.apple.NSEventThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":9},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":9},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":9},{"imageOffset":1756568,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":10},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":208630,"frames":[{"imageOffset":36426,"symbol":"__select","symbolLocation":10,"imageIndex":3},{"imageOffset":148095756,"symbol":"time_sleep","symbolLocation":140,"imageIndex":1},{"imageOffset":146693765,"symbol":"cfunction_vectorcall_O","symbolLocation":277,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395962,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30538,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":147408351,"symbol":"call_function","symbolLocation":431,"imageIndex":1},{"imageOffset":147395925,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":1},{"imageOffset":147365121,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":1},{"imageOffset":146415807,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":1},{"imageOffset":148102566,"symbol":"thread_run","symbolLocation":70,"imageIndex":1},{"imageOffset":147776041,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":211851,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":211940,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":211990,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":212041,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]}],
494 "usedImages" : [
495 {
496 "source" : "P",
497 "arch" : "x86_64",
498 "base" : 140712519831552,
499 "size" : 1634304,
500 "uuid" : "7797ea1d-f2d0-3dc7-950b-961dbc8a0b73",
501 "path" : "\/System\/Library\/Frameworks\/OpenGL.framework\/Versions\/A\/Resources\/GLEngine.bundle\/GLEngine",
502 "name" : "GLEngine"
503 },
504 {
505 "source" : "P",
506 "arch" : "x86_64",
507 "base" : 4449857536,
508 "CFBundleShortVersionString" : "3.1.0",
509 "CFBundleIdentifier" : "org.blenderfoundation.blender",
510 "size" : 210993152,
511 "uuid" : "11ec9ab2-102c-3dcb-87e9-f3f15347e3e8",
512 "path" : "\/Applications\/Blender\/Blender.app\/Contents\/MacOS\/Blender",
513 "name" : "Blender",
514 "CFBundleVersion" : "3.1.0 2022-01-31"
515 },
516 {
517 "source" : "P",
518 "arch" : "x86_64",
519 "base" : 5005115392,
520 "size" : 442368,
521 "uuid" : "cef5a27a-d50b-3020-af03-1734b19bc8c5",
522 "path" : "\/usr\/lib\/dyld",
523 "name" : "dyld"
524 },
525 {
526 "source" : "P",
527 "arch" : "x86_64",
528 "base" : 140703528181760,
529 "size" : 225280,
530 "uuid" : "5aa1e5be-b5b8-3a02-9885-a8c99e0ca378",
531 "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
532 "name" : "libsystem_kernel.dylib"
533 },
534 {
535 "source" : "P",
536 "arch" : "x86_64",
537 "base" : 140703526625280,
538 "size" : 290816,
539 "uuid" : "c8f7bfb6-4b1a-37cd-a32d-cd5069c916df",
540 "path" : "\/usr\/lib\/system\/libdispatch.dylib",
541 "name" : "libdispatch.dylib"
542 },
543 {
544 "source" : "P",
545 "arch" : "x86_64",
546 "base" : 140703528407040,
547 "size" : 49152,
548 "uuid" : "6c7561b4-4b92-3f45-921e-abe669299844",
549 "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
550 "name" : "libsystem_pthread.dylib"
551 },
552 {
553 "source" : "P",
554 "arch" : "x86_64",
555 "base" : 140703673565184,
556 "CFBundleShortVersionString" : "1.0",
557 "CFBundleIdentifier" : "com.apple.audio.caulk",
558 "size" : 143360,
559 "uuid" : "e76d1ab3-89c2-3a93-990b-30827fcf89b0",
560 "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
561 "name" : "caulk"
562 },
563 {
564 "source" : "P",
565 "arch" : "x86_64",
566 "base" : 140703554772992,
567 "CFBundleShortVersionString" : "5.0",
568 "CFBundleIdentifier" : "com.apple.audio.CoreAudio",
569 "size" : 7503872,
570 "uuid" : "33f55d9c-eaef-3fbd-add5-ed3e54925762",
571 "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
572 "name" : "CoreAudio",
573 "CFBundleVersion" : "5.0"
574 },
575 {
576 "source" : "P",
577 "arch" : "x86_64",
578 "base" : 4896071680,
579 "size" : 57344,
580 "uuid" : "099583aa-a77b-35dd-b414-f30dbc3a62c2",
581 "path" : "\/Applications\/Blender\/Blender.app\/Contents\/Resources\/3.1\/python\/lib\/python3.10\/lib-dynload\/_socket.cpython-310-darwin.so",
582 "name" : "_socket.cpython-310-darwin.so"
583 },
584 {
585 "source" : "P",
586 "arch" : "x86_64h",
587 "base" : 140703528722432,
588 "CFBundleShortVersionString" : "6.9",
589 "CFBundleIdentifier" : "com.apple.CoreFoundation",
590 "size" : 5255168,
591 "uuid" : "eab0e216-2a9e-31ce-9164-fdf3ebcf7bd3",
592 "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
593 "name" : "CoreFoundation",
594 "CFBundleVersion" : "1856.105"
595 },
596 {
597 "source" : "P",
598 "arch" : "x86_64",
599 "base" : 140703573217280,
600 "CFBundleShortVersionString" : "6.9",
601 "CFBundleIdentifier" : "com.apple.AppKit",
602 "size" : 15265792,
603 "uuid" : "d23b9681-3764-3298-a716-fbb511dd5a7c",
604 "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
605 "name" : "AppKit",
606 "CFBundleVersion" : "2113.20.111"
607 },
608 {
609 "size" : 0,
610 "source" : "A",
611 "base" : 0,
612 "uuid" : "00000000-0000-0000-0000-000000000000"
613 }
614],
615 "sharedCache" : {
616 "base" : 140703525179392,
617 "size" : 15216738304,
618 "uuid" : "40432a03-88d3-305f-9c0c-e7549e71d927"
619},
620 "vmSummary" : "ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)\nWritable regions: Total=6.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.2G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 384K 3 \nActivity Tracing 256K 1 \nCG backing stores 3840K 4 \nCG image 696K 18 \nColorSync 224K 25 \nCoreAnimation 144K 13 \nCoreGraphics 12K 2 \nCoreImage 4K 1 \nCoreUI image data 1120K 9 \nFoundation 16K 1 \nKernel Alloc Once 8K 1 \nMALLOC 5.4G 3083 \nMALLOC guard page 32K 8 \nMALLOC_LARGE (reserved) 256K 1 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated)\nOpenGL GLSL 256K 3 \nSTACK GUARD 132K 33 \nStack 102.8M 34 \nStack Guard 4K 1 \nVM_ALLOCATE 396.9M 3940 \nVM_ALLOCATE (reserved) 96.0M 1 reserved VM address space (unallocated)\n__DATA 101.7M 422 \n__DATA_CONST 17.5M 218 \n__DATA_DIRTY 782K 122 \n__FONT_DATA 4K 1 \n__GLSLBUILTINS 5176K 1 \n__LINKEDIT 708.7M 62 \n__OBJC_RO 81.8M 1 \n__OBJC_RW 3136K 2 \n__TEXT 576.7M 431 \n__UNICODE 588K 1 \ndyld private memory 1152K 3 \nmapped file 169.0M 30 \nshared memory 784K 17 \n=========== ======= ======= \nTOTAL 7.8G 8494 \nTOTAL, minus reserved VM space 7.5G 8494 \n",
621 "legacyInfo" : {
622 "threadTriggered" : {
623 "queue" : "com.apple.main-thread"
624 }
625},
626 "trialInfo" : {
627 "rollouts" : [
628 {
629 "rolloutId" : "60da5e84ab0ca017dace9abf",
630 "factorPackIds" : {
631
632 },
633 "deploymentId" : 240000008
634 },
635 {
636 "rolloutId" : "607844aa04477260f58a8077",
637 "factorPackIds" : {
638 "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"
639 },
640 "deploymentId" : 240000066
641 },
642 {
643 "rolloutId" : "601d9415f79519000ccd4b69",
644 "factorPackIds" : {
645 "SIRI_TEXT_TO_SPEECH" : "61f040507303d250981c88d9"
646 },
647 "deploymentId" : 240000377
648 },
649 {
650 "rolloutId" : "5fc94383418129005b4e9ae0",
651 "factorPackIds" : {
652
653 },
654 "deploymentId" : 240000225
655 },
656 {
657 "rolloutId" : "602ad4dac86151000cf27e46",
658 "factorPackIds" : {
659 "SIRI_DICTATION_ASSETS" : "6193d03f2171a2330e561dfc"
660 },
661 "deploymentId" : 240000298
662 },
663 {
664 "rolloutId" : "5ffde50ce2aacd000d47a95f",
665 "factorPackIds" : {
666
667 },
668 "deploymentId" : 240000102
669 }
670 ],
671 "experiments" : [
672 {
673 "treatmentId" : "c4ac6461-f0e0-47b0-a630-f7739342ca3b",
674 "experimentId" : "60c785f07aa5af21f0101872",
675 "deploymentId" : 400000012
676 }
677 ]
678}
679}
680
681Model: Macmini8,1, BootROM 1715.60.5.0.0 (iBridge: 19.16.10647.0.0,0), 6 processors, 6-Core Intel Core i7, 3,2 GHz, 8 GB, SMC
682Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
683Graphics: AMD Radeon RX Vega 56, AMD Radeon RX Vega 56, PCIe, 8 GB
684Display: BenQ EL2870U, 5120 x 2880 (5K/UHD+ - Ultra High Definition Plus), Main, MirrorOff, Online
685Memory Module: BANK 0/ChannelA-DIMM0, 4 GB, DDR4, 2667 MHz, Micron, 4ATF51264HZ-2G6E3
686Memory Module: BANK 2/ChannelB-DIMM0, 4 GB, DDR4, 2667 MHz, Micron, 4ATF51264HZ-2G6E3
687AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd
688Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
689Network Service: Wi-Fi, AirPort, en1
690PCI Card: AMD Radeon RX Vega 56, Display Controller, Thunderbolt@198,0,0
691PCI Card: pci1002,aaf8, Audio Device, Thunderbolt@198,0,1
692USB Device: Portable SSD T5
693USB Device: USB31Bus
694USB Device: USB3.1 Hub
695USB Device: USB Storage
696USB Device: USB2.1 Hub
697USB Device: Gaming_Mouse
698USB Device: USB DEVICE
699USB Device: Portable SSD T5
700USB Device: T2Bus
701USB Device: Headset
702USB Device: Apple T2 Controller
703Thunderbolt Bus: Mac mini, Apple Inc., 47.5
704Thunderbolt Bus: Mac mini, Apple Inc., 47.5
705Thunderbolt Device: Core X, Razer, 1, 33.1
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Feb 4 2022, 5:11 AM
Richard Antalik (ISS) updated the task description. (Show Details)
Please upload sample file and steps to reproduce the crash.
