Camera data node "View Vector" differs between Cycles and Eevee in the viewport when used as world output
Needs Information from Developers, NormalPublic
Operating system: Windows 10
Graphics card: RX580
Broken: 3.0.0
The camera data node's "View Vector" output does not work under Cycles in the viewport when used in World shaders.
Note that it _does_ work as expected if there's an active camera (although it's not quite as bright as Eevee).
Eevee viewport rendering:
Cycles viewport rendering:
Cycles viewport (with active camera) rendering:
Connect the camera data "View Vector" output directly to the "Surface" input of the "World Output" node.
Switch to rendered view.
Observe that the view vector is incorrect when navigating the viewport in Cycles, but correct when in "camera view" (numpad 0) or in Eevee.
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from Developers.Feb 9 2022, 2:45 AM
Thanks for the report. Not sure about the expected behavior but can see some differences in Cycles. Neither shows correct result to me with active camera.
maybe developers can clarify this
EEVEECyclesCycles (active camera)
