Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-02-12 01:56, hash: rB517afcc858b0
Caused by rB507a4deef149: Fix invalid creation of partial image updater
changing which output is connected to composite node in the compositor no longer updates the image editor
Steps to Reproduce
- Enable some passes, enable use nodes in the compositor
- Connect the render layer output to the Composite node.
- Open an image editor open alongside it (image editor should be set to render result).
- Hit render (default scene will suffice)
- connect a different render layer output to composite node. Nothing happens. Now zoom in on the image editor, the image editor will now update.
This happens for any changes made in the node editor. For example adding an RGB to BW node between the render layer and the composite/view node will have no effect until zooming either.
This may also be causing saved images (when doing a ctrl f12 animation) to not reflect the effects of the compositor.
Test File:
