Operating system: W10
Graphics card: Happens on several other pc's of mine and at work also
Blender Version 3.0
Broken:
(example: 2.79b release)
Worked: (optional) It worked but this has happened 3 times with me. I Have to re do the whole add metarig , position and generate.But the one that I already spent many hours on already worked fine before,but then for some reason it does this, see youtube link I found of someone that has the EXACT same problem.Happens in Blender 2.93 and other versions also.
Short description of error> See https://www.youtube.com/watch?v=ccFkm2NTQRg&ab_channel=BackGroundIndieGamer
Based on the default startup or an attached .blend file (as simple as possible):
This happens when I generate the metarig and then use automatic weights from mesh to the metarig.All loc,rot,scale applied.
