Regression: Toggle X-Ray breaks Face selection mode when Show On Cage active.
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: GeForce GT 740/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-02-21 23:16, hash: rBec5bbebf3ee1
Worked: 3.0.1 Official
While in edit mode, mesh becomes unselectable when Toggle X-Ray (not wireframe viewport shading) is active if mesh selection mode is set to Faces when objects have modifiers where Show On Cage and Show On Edit Mode options are active (i.e. subsurf modifier). Note you can still press A to select all in this state and you can select while verts or edge selection modes are active but not Faces.
  1. Open Blender.
  2. Add a subsurf modifier to the default cube.
  3. Enable the "Show On Cage" setting of the subsurf modifier.
  4. Enable Toggle X-Ray (not Wireframe viewport shading).
  5. Change mesh selection type to Faces.
  6. Try to select with any Blender selection method, no selection methods work while Face selection mode is active.
Jesse Yurkovich (deadpin) changed the task status from Needs Triage to Confirmed.Feb 23 2022, 2:25 AM
This is related to the Viewport -> Subdivision -> GPU Subdivision user preference. Disabling it will allow things to work.
CC @Kévin Dietrich (kevindietrich)
Jesse Yurkovich (deadpin) triaged this task as High priority.Feb 23 2022, 10:50 AM
Philipp Oeser (lichtwerk) renamed this task from Toggle X-Ray breaks Face selection mode when Show On Cage active. to Regression: Toggle X-Ray breaks Face selection mode when Show On Cage active..Feb 23 2022, 11:06 AM
