Blender 3.1.0 Suddenly Couldn't scale object
Operating system:
Graphics card:
Broken: Blender 3.1.0
When I shift + A new object like cube or sphere ,it couldn't scale
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Feb 25 2022, 5:06 AM
Hi, thanks for the report.
Blender 3.1.0 "Suddenly" Couldn't scale object
Do you mean this was working before on same version?
Check if you can still reproduce with factory settings: FileDefaultsLoad Factory Settings
I Copied to another file ,it works......
If I interpreted that correctly, you are unable to scale the object in particular file, right?
Can you upload that file here? I suspect Location is checked in Transform affect only popover (just a guess)
Thank you for the file. In sidebar, disable Location option from Transform -Affect only
This is not a bug so closing the report. Feel free to comment if issue persists.
