Blender Flickering
Closed, DuplicatePublic
Operating system: Windows 10
Graphics card: RX580
Blender Version : 3.0.1
Hi, I recently changed some stuff on my pc, as changing User's name, did a huge windows 10 update, and updating my graphic drivers. And now, when I start blender, one time out of two the whole UI is flickering and it crashes when i wanna load a file, or sometimes just by trying to go in the settings. So I formated my Window's SSD, everything was clean, and downloaded Blender again. The flickering didn't disappeared, I tried to reset drivers, and now i'm wondering if I should flash my graphic card (I don't really understand what it means).
Thanks a lot for your help <3
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Feb 26 2022, 1:43 PM
Hi, Thanks for the report.
Problem seems related to your GPU driver. Are you using the latest one?: https://www.amd.com/en/support/graphics/radeon-500-series/radeon-rx-500-series/radeon-rx-580
Can you provide System info file?: HelpSave System Info
Please test if problem is replicable when running blender from blender_debug_gpu_glitchworkaround.cmd (enables all available workarounds for driver related issues)
Similar issue was reported before but got closed as report went cold for over a week: T94012
Hi, thanks for the answer, here is my system info
I'm almost sure to have the latest driver version, I downloaded it again to be sure. I tried the debug blender, it's not solving the problem. It seems to work a little better though, but i'm not sure. I still have crashes when I try to save, or just by navigating into the directory window. I can give you the output files from the log.
DEBUG OUTPUT
BLENDER SYSTEM INFO
Right now i'm using Blender version 2.80.75 and it works fine but i have thos type of graphic bugs
Thanks a lot for helping me.
Hi, thank you for the information.
Another similar report is lying around so I will merge your report there: T95555: Blender suddenly close himself (AMD)
(Just a guess) That flickering is probably related to FreeSync? Can you reproduce when disabling it from Radeon settings?: https://www.amd.com/en/support/kb/faq/dh-013
Feel free to comment there
Ok so finally, here is the solution to my issue :
I believe I've found a solution:
Uninstalled AMD Software Suite
Uninstalled Graphics Driver Via Device Manager
Windows Initially replaced graphics driver in device manager with Generic Windows Driver but AMD 6900 XT was automatically reinstalled.
Driver Version in Device Manager shows 30.0.13023.1012 10/18/2021
Now Cura and Blender no longer exhibit issues mentioned before
Now I Reinstalled radeon-software-adrenalin-2020-22.1.2-win10-win11-64bit-jan25
Recommended reinstall of Version 22.1.2. (Shows 30.0.14023.3004 1/18/2022 in device manager)
Checked Factory Reset as well
All problems have gone away now.
