Some properties, like Dimensions, remain editable in 3DView for linked etc. IDs
Confirmed, NormalPublicBUG
In the 3DView properties panel, some non-RNA properties like Dimensions of objects remain editable, even for linked objects.
Reproducible at least since 2.93, so not a (recent) regression.
NOTE: ideally those non-RNA UI widgets should still use RNA_property_editable_info to check if they can edit the data, and display a proper explanation if not.
Bastien Montagne (mont29) changed the task status from Needs Triage to Confirmed.Mar 1 2022, 5:41 PM
Bastien Montagne (mont29) created this task.
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".
