Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.07
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
When using the RGB/Vector/Float curves nodes and choosing the Extend Horizontal option, the output is the same as with Extend Extrapolated if the X value of the last point of the curve widget curve is greater than 1 and the Y value is smaller than 1.
The inverse is the case for the first point, so the output is the same as with Extend Extrapolated if the x value of the first point is smaller than 0 and the y value is greater than 0.
The image below shows the areas where, if you place the point, the result in the render will show as Extrapolated instead of Horizontal:
- Open attached file
- Set Cycles Render Preview display mode to better visualize the problem through displace (Eevee has no such issue.)
The test files only include the case for the last point and for the RGB curves node, but everything is applicable to the first point and the Vector/Float curves node.
Each of the three objects shows the wrong result. The beginning and end of the geometry should be Horizontal.
