Tangent shader node & subdivision surface crashes blender
Operating system: windows 11
Graphics Card: NVIDIA GeForce RTX 2060 SUPER
Processor: 12th Gen Intel(R) Core(TM) i5-12600K, 3686 Mhz, 10 Core(s), 16 Logical Processor(s)
Crash to desktop: 3.1.0 Candidate (7th and 3rd of march builds)
Bugged display but no crash: 3.1.0 Beta (27th feb build and older)
Worked: Blender 3.0.0
Using a shader with the Tangent node set to UV map mode, together with a subdiv surface modifier and setting the object to shade smooth immediatly crashes blender.
  1. set viewport to shaded
  2. on default cube assign a shader that uses the Tangent node
  3. set the Tangent node to UV map mode and pick the default UV
  4. set the cube to shade smooth
  5. add a subdivision modifier to the cube
Ethan Hall (Ethan1080) changed the task status from Needs Triage to Confirmed.Mar 7 2022, 8:07 PM
Can confirm. Occurs only with Viewport GPU Subdivision enabled.
Test file:
  1. Make sure Viewport GPU Subdivision is enabled.
  2. Enable the Subdivision modifier in the viewport.
