Rigify Already Registered as a Subclass (Traceback) Error
Operating system: Windows 10
Graphics card: NVIDIA RTX 3060Ti
Broken: 3.1.0
When trying to enable the Rigify Addon, I am met with an error. It is as follows:
  File "D:\SteamLibrary\steamapps\common\Blender\3.1\scripts\modules\addon_utils.py", line 387, in enable
    mod.register()
  File "D:\SteamLibrary\steamapps\common\Blender\3.1\scripts\addons\rigify\__init__.py", line 500, in register
    ui.register()
  File "D:\SteamLibrary\steamapps\common\Blender\3.1\scripts\addons\rigify\ui.py", line 1418, in register
    animation_register()
  File "D:\SteamLibrary\steamapps\common\Blender\3.1\scripts\addons\rigify\utils\animation.py", line 956, in register
    register_class(RIGIFY_OT_get_frame_range)
ValueError: register_class(...): already registered as a subclass 'RIGIFY_OT_get_frame_range'
Using the Default Factory Settings attempt to enable the rigify addon.
Related Objects
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 23 2022, 1:22 PM
Do you have any feature set installed? Not sure if those reset with factory settings.
Just a poke regarding my inquiry above, otherwise, we will have to archive this for now.
