Operating system: Windows 10 Pro
Graphics card: Zotac 3080 AMP HOLO
Broken: 3.1.0
Worked: 3.0.0
Rigid bodies with constraints have glitched subframes causing motion blur problems
Open the attached file or do the following steps:
- Duplicate the default cube.
- Select both cubes and go to Object > Rigid Body > Add Active.
- With both cubes still selected, go to Object > Rigid Body > Connect.
- Bake the rigid body simulation.
- Enable Motion Blur under Render Properties. In Eevee, increasing the steps can better show the trail.
Additional details
- Enabling Show Subframes under the Playback menu and scrubbing shows the glitched animation.
- Opening the file in Blender 3.0 with the same rigid body cache shows normal behavior.
Thanks in advance! ❤️
