Discombobulator not working oh
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1650 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
Broken: version: 2.93.8, branch: master, commit date: 2022-02-01 21:14, hash: rB09da7f489ad9
Addon Information
Name: Discombobulator (0, 1, 0)
Author: Evan J. Rosky (syrux)
I’ve tried this in blender 3.0.1 and 3.1 and 2.93.8 and no matter what I do do I can’t really get discombobulator to show up in my add/ mesh menu. I’m following the tutorial by Ian Hubert which is modeling sci-fi megastructures… And at 6: 36 he goes to add the discombobulator add on …which I do …I enable it in preferences but when I go to look… it is not in my add mesh menu …even though I followed his instructions exactly …here is my blender file https://drive.google.com/file/d/1xC9Po7LiRYQnGL4y6vy5sQK1dmbsqxY4/view?usp=sharing
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.Mar 20 2022, 10:06 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
The Discombobulator add-on is showing in the UI for me in Blender 2.93, 3.0, 3.1, and 3.2.
It should be noted that the Discombobulator UI option will only show up if you are in object mode. And it will only be usable if you have selected a mesh. Are you meeting those conditions?
Alaska (Alaska) closed this task as Archived.Mar 28 2022, 1:42 AM
