All wrong with the window mesh
Operating system: Linux-5.10.87-1.0-lts-i686-with-glibc2.33 32 Bits
Graphics card: AMD KAVERI (DRM 2.50.0, 5.10.87-1.0-lts, LLVM 12.0.1) AMD 4.5 (Core Profile) Mesa 21.2.1
Broken: version: 2.93.4, branch: makepkg (modified), commit date: 2021-08-31 09:23, hash: rBb7205031cec4
Addon Information
Name: Archimesh (1, 2, 2)
Author: Antonio Vazquez (antonioya)
It's where you create/add new mesh of window.
Wrong distribution and visualization of properties. All new panels tried fit all in one line properties. Don't show good properties or all properties. Doesn't match decimal/floats numbers with the integer numbers (blender use metric number for all the mesh), and even more errors.
https://0x0.st/oNfW.png
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 23 2022, 3:20 PM
I am not entirely sure what the issue you are describing is.
Are you talking about the UI alignments of the properties?
Which properties are missing?
Match how? If you enter a float value it will become a different integer values?
