Weird Shapes on using Subdivision surface modifier
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: Intel(R) HD Graphics 520 Intel 4.5.0 - Build 27.20.100.8681
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: rBc77597cd0e15
Weird shapes seem to appear when the subdivision modifier is used.
Interestingly it gets corrected when applied. It happens only incase of not applying. When the modifier hasnt been applied there are weird shapes observed.
  1. Open the attached blend file.
  2. Add a subdivision surface modifier
[Based on the default startup or an attached .blend file (as simple as possible)
Thanks!
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Mar 31 2022, 2:11 PM
Screenshot suggests there is a Sphere obj in the scene, but there isnt.
Can you clarify?
Also please check this option in User Preferences:
Philipp Oeser (lichtwerk) closed this task as Archived.Apr 26 2022, 8:55 AM
