Operating system: Linux-5.17.0-1-amd64-x86_64-with-glibc2.33 64 Bits
Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 510.68.02
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-05-06 21:48, hash: rB98a04ed45242
Worked: Unsure as I have tested versions dating back to Blender 2.79 and they don't work either.
Many of the outputs of the Light Path node doesn't work when used on lights.
- Change the render engine to Cycles.
- Select a light in the scene and give it a shader node setup.
- In the shader node setup, use the Light Path node to drastically change the look of the node under specific conditions (An example image of a node setup can be found below). You will notice it doesn't work in a lot of situations. Here is a list of outputs that don't appear to work properly.
- Is Camera Ray
- Is Diffuse Ray
- Is Glossy Ray
- Is Singular Ray
- Is Reflection Ray
- Is Transmission Ray
Example node setup:
Here is a file with steps 1-3 done for you:
