cmd+z crash
Operating system: macOS-12.3-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 570X OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.13
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: rBcc66d1020c3b
cmd+z serveal times,it always crashed
apple report below
Translated Report (Full Report Below)
Process:               Blender [65686]
Path:                  /Applications/Blender 3.1.2.app/Contents/MacOS/Blender
Identifier:            org.blenderfoundation.blender
Version:               3.1.2 (3.1.2 2022-04-01)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-05-10 11:10:46.5481 +0800
OS Version:            macOS 12.3 (21E230)
Report Version:        12
Anonymous UUID:        35B468B4-3456-9C66-AF92-6373F96C1165
Time Awake Since Boot: 150000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       UNKNOWN_0xD at 0x0000000000000000
Exception Codes:       0x000000000000000d, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [65686]
VM Region Info: 0 is not in any region.  Bytes before following region: 4405927936
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      1069d2000-11331e000    [201.3M] r-x/r-x SM=COW  ...MacOS/Blender
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   Blender                       	       0x107c0dd98 ui_but_equals_old + 8
1   Blender                       	       0x107c0e931 UI_block_update_from_old + 1089
2   Blender                       	       0x107c0eb38 UI_block_end_ex + 152
3   Blender                       	       0x107d766d6 draw_outliner + 2774
4   Blender                       	       0x107d89e40 outliner_main_region_draw(bContext const*, ARegion*) + 32
5   Blender                       	       0x1076745b1 ED_region_do_draw + 337
6   Blender                       	       0x1070f82ed wm_draw_update + 1757
7   Blender                       	       0x1070f5810 WM_main + 48
8   Blender                       	       0x106b50f89 main + 873
9   dyld                          	       0x12990651e start + 462
Thread 1:
0   libsystem_kernel.dylib        	    0x7ff81f5b99b6 semaphore_wait_trap + 10
1   libdispatch.dylib             	    0x7ff81f43b7ce _dispatch_sema4_wait + 16
2   libdispatch.dylib             	    0x7ff81f43bc9d _dispatch_semaphore_wait_slow + 98
3   Blender                       	       0x10eeccc1f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
4   Blender                       	       0x10eecb6ae void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
5   libsystem_pthread.dylib       	    0x7ff81f5f64e1 _pthread_start + 125
6   libsystem_pthread.dylib       	    0x7ff81f5f1f6b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:: AMCP Logging Spool
1   caulk                         	    0x7ff8280cc2e0 caulk::mach::semaphore::wait_or_error() + 16
2   caulk                         	    0x7ff8280b4102 caulk::concurrent::details::worker_thread::run() + 36
3   caulk                         	    0x7ff8280b3dc6 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41
4   libsystem_pthread.dylib       	    0x7ff81f5f64e1 _pthread_start + 125
5   libsystem_pthread.dylib       	    0x7ff81f5f1f6b thread_start + 15
Thread 7:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        	    0x7ff81f5b997a mach_msg_trap + 10
1   libsystem_kernel.dylib        	    0x7ff81f5b9ce8 mach_msg + 56
2   CoreAudio                     	    0x7ff82122cd71 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3   CoreAudio                     	    0x7ff8210b7e63 HALC_ProxyIOContext::IOWorkLoop() + 3909
4   CoreAudio                     	    0x7ff8210b6959 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 63
5   CoreAudio                     	    0x7ff8212827a8 HALB_IOThread::Entry(void*) + 72
6   libsystem_pthread.dylib       	    0x7ff81f5f64e1 _pthread_start + 125
7   libsystem_pthread.dylib       	    0x7ff81f5f1f6b thread_start + 15
Thread 8:
1   Blender                       	       0x1070ec0e8 tbb::internal::rml::private_worker::run() + 344
2   Blender                       	       0x1070ebf89 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3   libsystem_pthread.dylib       	    0x7ff81f5f64e1 _pthread_start + 125
4   libsystem_pthread.dylib       	    0x7ff81f5f1f6b thread_start + 15
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
0   libsystem_kernel.dylib        	    0x7ff81f5c0092 __accept + 10
1   _socket.cpython-310-darwin.so 	       0x12f763388 sock_accept_impl + 24
2   _socket.cpython-310-darwin.so 	       0x12f7637e2 sock_call_ex + 402
3   _socket.cpython-310-darwin.so 	       0x12f761080 sock_accept + 144
4   Blender                       	       0x10f58f857 method_vectorcall_NOARGS + 135
5   Blender                       	       0x10f67abef call_function + 431
6   Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
7   Blender                       	       0x10f670311 _PyEval_Vector + 145
8   Blender                       	       0x10f67abef call_function + 431
9   Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
10  Blender                       	       0x10f670311 _PyEval_Vector + 145
11  Blender                       	       0x10f67abef call_function + 431
12  Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
13  Blender                       	       0x10f670311 _PyEval_Vector + 145
14  Blender                       	       0x10f67abef call_function + 431
15  Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
16  Blender                       	       0x10f670311 _PyEval_Vector + 145
17  Blender                       	       0x10f5886cf method_vectorcall + 367
18  Blender                       	       0x10f7243b6 thread_run + 70
19  Blender                       	       0x10f6d4839 pythread_wrapper + 25
20  libsystem_pthread.dylib       	    0x7ff81f5f64e1 _pthread_start + 125
21  libsystem_pthread.dylib       	    0x7ff81f5f1f6b thread_start + 15
Thread 14:
0   libsystem_kernel.dylib        	    0x7ff81f5c1d5a __select + 10
1   Blender                       	       0x10f72291c time_sleep + 140
2   Blender                       	       0x10f5cc495 cfunction_vectorcall_O + 277
3   Blender                       	       0x10f67abef call_function + 431
4   Blender                       	       0x10f677b8a _PyEval_EvalFrameDefault + 30538
5   Blender                       	       0x10f670311 _PyEval_Vector + 145
6   Blender                       	       0x10f67abef call_function + 431
7   Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
8   Blender                       	       0x10f670311 _PyEval_Vector + 145
9   Blender                       	       0x10f67abef call_function + 431
10  Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
11  Blender                       	       0x10f670311 _PyEval_Vector + 145
12  Blender                       	       0x10f5886cf method_vectorcall + 367
13  Blender                       	       0x10f7243b6 thread_run + 70
14  Blender                       	       0x10f6d4839 pythread_wrapper + 25
15  libsystem_pthread.dylib       	    0x7ff81f5f64e1 _pthread_start + 125
16  libsystem_pthread.dylib       	    0x7ff81f5f1f6b thread_start + 15
Thread 15:
0   libsystem_kernel.dylib        	    0x7ff81f5c00aa poll + 10
1   select.cpython-310-darwin.so  	       0x121bbdd63 select_poll_poll + 291
2   Blender                       	       0x10f58f66c method_vectorcall_FASTCALL + 140
4   Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
10  Blender                       	       0x10f677c2c _PyEval_EvalFrameDefault + 30700
12  Blender                       	       0x10f67abef call_function + 431
13  Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
14  Blender                       	       0x10f670311 _PyEval_Vector + 145
15  Blender                       	       0x10f58862c method_vectorcall + 204
16  Blender                       	       0x10f67abef call_function + 431
17  Blender                       	       0x10f677cd3 _PyEval_EvalFrameDefault + 30867
18  Blender                       	       0x10f670311 _PyEval_Vector + 145
19  Blender                       	       0x10f67abef call_function + 431
20  Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
21  Blender                       	       0x10f670311 _PyEval_Vector + 145
22  Blender                       	       0x10f67abef call_function + 431
23  Blender                       	       0x10f677b65 _PyEval_EvalFrameDefault + 30501
24  Blender                       	       0x10f670311 _PyEval_Vector + 145
25  Blender                       	       0x10f5886cf method_vectorcall + 367
26  Blender                       	       0x10f7243b6 thread_run + 70
27  Blender                       	       0x10f6d4839 pythread_wrapper + 25
28  libsystem_pthread.dylib       	    0x7ff81f5f64e1 _pthread_start + 125
29  libsystem_pthread.dylib       	    0x7ff81f5f1f6b thread_start + 15
Thread 16:: com.apple.NSEventThread
2   CoreFoundation                	    0x7ff81f6bccdd __CFRunLoopServiceMachPort + 319
3   CoreFoundation                	    0x7ff81f6bb368 __CFRunLoopRun + 1276
4   CoreFoundation                	    0x7ff81f6ba7ac CFRunLoopRunSpecific + 562
5   AppKit                        	    0x7ff82224efee _NSEventThread + 132
Thread 17:
Thread 18:
0   libsystem_pthread.dylib       	    0x7ff81f5f1f48 start_wqthread + 0
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0xff2c2c2cff2c2c2c  rcx: 0x0000000000000000  rdx: 0x00000000006a6200
  rdi: 0x00007f8b4350ce08  rsi: 0xff2c2c2cff2c2c2c  rbp: 0x00007ff7b952d520  rsp: 0x00007ff7b952d520
   r8: 0x0000000000000000   r9: 0x0000000000002800  r10: 0x0000000000008014  r11: 0x0000000000003fff
  r12: 0x00007f8b424e4088  r13: 0x00007f8b4350ce08  r14: 0x00006000003a4148  r15: 0x00007f8b4517c118
  rip: 0x0000000107c0dd98  rfl: 0x0000000000010282  cr2: 0x0000000129990383
Logical CPU:     0
Error Code:      0x00000000
Trap Number:     13
Thread 0 instruction stream:
  c3 0f 1f 80 00 00 00 00-55 48 89 e5 41 56 53 48  ........UH..AVSH
  8b 5f 10 48 85 db 74 27-49 89 f6 66 2e 0f 1f 84  ._.H..t'I..f....
  00 00 00 00 00 0f 1f 00-4c 89 f7 48 89 de e8 25  ........L..H...%
  00 00 00 84 c0 75 0a 48-8b 1b 48 85 db 75 e9 31  .....u.H..H..u.1
  db 48 89 d8 5b 41 5e 5d-c3 66 2e 0f 1f 84 00 00  .H..[A^].f......
  00 00 00 0f 1f 44 00 00-55 48 89 e5 0f b7 47 2c  .....D..UH....G,
 [66]3b 46 2c 75 4e 48 8b-87 58 03 00 00 48 3b 86  f;F,uNH..X...H;.	<==
  58 03 00 00 75 3e 48 8b-87 60 03 00 00 48 3b 86  X...u>H..`...H;.
  60 03 00 00 75 2e 8b 86-68 03 00 00 39 87 68 03  `...u...h...9.h.
  00 00 75 20 48 8b 87 90-02 00 00 48 3b 86 90 02  ..u H......H;...
  00 00 75 10 48 8b 87 a8-02 00 00 48 3b 86 a8 02  ..u.H......H;...
  00 00 74 04 31 c0 5d c3-48 8b 8e 98 02 00 00 48  ..t.1.].H......H
Binary Images:
       0x1069d2000 -        0x11331dfff org.blenderfoundation.blender (3.1.2) <886d906a-93f0-3952-a46f-144e5205f719> /Applications/Blender 3.1.2.app/Contents/MacOS/Blender
       0x129901000 -        0x12996cfff dyld (*) <dd9e80de-fb3b-349b-96a4-46874ad34d11> /usr/lib/dyld
    0x7ff81f5b8000 -     0x7ff81f5effff libsystem_kernel.dylib (*) <26a59789-b846-3ed4-96dc-8dbef3c0c8e7> /usr/lib/system/libsystem_kernel.dylib
    0x7ff81f438000 -     0x7ff81f47efff libdispatch.dylib (*) <31d69d55-9895-326c-ad61-621c5ca87314> /usr/lib/system/libdispatch.dylib
    0x7ff81f5f0000 -     0x7ff81f5fbfff libsystem_pthread.dylib (*) <2f6c275d-7e14-3d31-a924-e1bb41d2415f> /usr/lib/system/libsystem_pthread.dylib
    0x7ff8280b2000 -     0x7ff8280d3fff com.apple.audio.caulk (1.0) <0b849791-3a62-33d1-8cf1-9c612a9d8e18> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7ff820efe000 -     0x7ff821631fff com.apple.audio.CoreAudio (5.0) <e432684f-546f-3931-af3e-a0281c23a244> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
       0x12f75f000 -        0x12f76cfff _socket.cpython-310-darwin.so (*) <099583aa-a77b-35dd-b414-f30dbc3a62c2> /Applications/Blender 3.1.2.app/Contents/Resources/3.1/python/lib/python3.10/lib-dynload/_socket.cpython-310-darwin.so
       0x121bbc000 -        0x121bc0fff select.cpython-310-darwin.so (*) <16f40aa0-5cbc-3ea0-92f2-cca27bea0643> /Applications/Blender 3.1.2.app/Contents/Resources/3.1/python/lib/python3.10/lib-dynload/select.cpython-310-darwin.so
    0x7ff81f63d000 -     0x7ff81fb3efff com.apple.CoreFoundation (6.9) <743f0cb7-e962-3e42-8653-7bd141129561> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff8220a3000 -     0x7ff822f30fff com.apple.AppKit (6.9) <36ec7e1b-ab12-377b-b3eb-ffc5baabee9f> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 23
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.5G resident=0K(0%) swapped_out_or_unallocated=1.5G(100%)
Writable regions: Total=1.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.7G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               128K        1
Activity Tracing                   256K        1
CG backing stores                 3840K        4
CG image                            96K        8
ColorSync                          100K        9
CoreAnimation                      124K        7
CoreGraphics                        12K        2
CoreImage                            4K        1
CoreUI image data                 1036K        7
Foundation                          16K        1
Kernel Alloc Once                    8K        1
MALLOC                             1.0G      593
MALLOC guard page                   32K        8
MALLOC_LARGE (reserved)            256K        2         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           256.0M        1         reserved VM address space (unallocated)
OpenGL GLSL                        256K        3
STACK GUARD                         96K       24
Stack                             99.7M       26
Stack Guard                          4K        1
VM_ALLOCATE                      186.9M      329
VM_ALLOCATE (reserved)            96.0M        2         reserved VM address space (unallocated)
__DATA                           110.4M      572
__DATA_CONST                      29.2M      324
__DATA_DIRTY                      1542K      195
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       719.8M       77
__OBJC_RO                         82.6M        1
__OBJC_RW                         3200K        2
__TEXT                           776.4M      573
__UNICODE                          592K        1
dyld private memory               1152K        3
mapped file                      172.9M       28
shared memory                     1284K       17
TOTAL                              3.5G     2826
TOTAL, minus reserved VM space     3.2G     2826
Full Report
{"app_name":"Blender","timestamp":"2022-05-10 11:10:47.00 +0800","app_version":"3.1.2","slice_uuid":"886d906a-93f0-3952-a46f-144e5205f719","build_version":"3.1.2 2022-04-01","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.3 (21E230)","incident_id":"7A2BCA27-CB0A-4A92-9289-BB4B4B1706AF","name":"Blender"}
  "uptime" : 150000,
  "procLaunch" : "2022-05-10 10:18:01.5772 +0800",
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "iMac19,1",
  "procStartAbsTime" : 149882388505649,
  "coalitionID" : 175391,
  "osVersion" : {
    "train" : "macOS 12.3",
    "build" : "21E230",
    "releaseType" : "User"
  "captureTime" : "2022-05-10 11:10:46.5481 +0800",
  "incident" : "7A2BCA27-CB0A-4A92-9289-BB4B4B1706AF",
  "bug_type" : "309",
  "pid" : 65686,
  "procExitAbsTime" : 153047215997583,
  "cpuType" : "X86-64",
  "procName" : "Blender",
  "procPath" : "\/Applications\/Blender 3.1.2.app\/Contents\/MacOS\/Blender",
  "bundleInfo" : {"CFBundleShortVersionString":"3.1.2","CFBundleVersion":"3.1.2 2022-04-01","CFBundleIdentifier":"org.blenderfoundation.blender"},
  "storeInfo" : {"deviceIdentifierForVendor":"B46F7F0D-AA84-5DB1-84CE-820DB151F71E","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "org.blenderfoundation.blender",
  "crashReporterKey" : "35B468B4-3456-9C66-AF92-6373F96C1165",
  "sip" : "enabled",
  "vmRegionInfo" : "0 is not in any region.  Bytes before following region: 4405927936\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      1069d2000-11331e000    [201.3M] r-x\/r-x SM=COW  ...MacOS\/Blender",
  "isCorpse" : 1,
  "exception" : {"codes":"0x000000000000000d, 0x0000000000000000","rawCodes":[13,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"UNKNOWN_0xD at 0x0000000000000000"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":65686},
  "vmregioninfo" : "0 is not in any region.  Bytes before following region: 4405927936\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      1069d2000-11331e000    [201.3M] r-x\/r-x SM=COW  ...MacOS\/Blender",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":23},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":2088165,"instructionState":{"instructionStream":{"bytes":[195,15,31,128,0,0,0,0,85,72,137,229,65,86,83,72,139,95,16,72,133,219,116,39,73,137,246,102,46,15,31,132,0,0,0,0,0,15,31,0,76,137,247,72,137,222,232,37,0,0,0,132,192,117,10,72,139,27,72,133,219,117,233,49,219,72,137,216,91,65,94,93,195,102,46,15,31,132,0,0,0,0,0,15,31,68,0,0,85,72,137,229,15,183,71,44,102,59,70,44,117,78,72,139,135,88,3,0,0,72,59,134,88,3,0,0,117,62,72,139,135,96,3,0,0,72,59,134,96,3,0,0,117,46,139,134,104,3,0,0,57,135,104,3,0,0,117,32,72,139,135,144,2,0,0,72,59,134,144,2,0,0,117,16,72,139,135,168,2,0,0,72,59,134,168,2,0,0,116,4,49,192,93,195,72,139,142,152,2,0,0,72],"offset":96}},"threadState":{"r13":{"value":140236106550792},"rax":{"value":0},"rflags":{"value":66178},"cpu":{"value":0},"r14":{"value":105553120084296},"rsi":{"value":18387119950418160684},"r8":{"value":0},"cr2":{"value":4992861059},"rdx":{"value":6971904},"r10":{"value":32788},"r9":{"value":10240},"r15":{"value":140236136366360},"rbx":{"value":18387119950418160684},"trap":{"value":13},"err":{"value":0},"r11":{"value":16383},"rip":{"value":4425047448,"matchesCrashFrame":1},"rbp":{"value":140701942863136},"rsp":{"value":140701942863136},"r12":{"value":140236089606280},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":140236106550792}},"queue":"com.apple.main-thread","frames":[{"imageOffset":19119512,"symbol":"ui_but_equals_old","symbolLocation":8,"imageIndex":0},{"imageOffset":19122481,"symbol":"UI_block_update_from_old","symbolLocation":1089,"imageIndex":0},{"imageOffset":19123000,"symbol":"UI_block_end_ex","symbolLocation":152,"imageIndex":0},{"imageOffset":20596438,"symbol":"draw_outliner","symbolLocation":2774,"imageIndex":0},{"imageOffset":20676160,"symbol":"outliner_main_region_draw(bContext const*, ARegion*)","symbolLocation":32,"imageIndex":0},{"imageOffset":13247921,"symbol":"ED_region_do_draw","symbolLocation":337,"imageIndex":0},{"imageOffset":7496429,"symbol":"wm_draw_update","symbolLocation":1757,"imageIndex":0},{"imageOffset":7485456,"symbol":"WM_main","symbolLocation":48,"imageIndex":0},{"imageOffset":1568649,"symbol":"main","symbolLocation":873,"imageIndex":0},{"imageOffset":21790,"symbol":"start","symbolLocation":462,"imageIndex":1}]},{"id":2088179,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":3},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":3},{"imageOffset":139439135,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":0},{"imageOffset":139433646,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088180,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":3},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":3},{"imageOffset":139439135,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":0},{"imageOffset":139433646,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088181,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":3},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":3},{"imageOffset":139439135,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":0},{"imageOffset":139433646,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088182,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":3},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":3},{"imageOffset":139439135,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":0},{"imageOffset":139433646,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088183,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":3},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":3},{"imageOffset":139439135,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":0},{"imageOffset":139433646,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088186,"name":"AMCP Logging Spool","frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":107232,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":5},{"imageOffset":8450,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":5},{"imageOffset":7622,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":5},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088190,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":2},{"imageOffset":3337585,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":111,"imageIndex":6},{"imageOffset":1810019,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3909,"imageIndex":6},{"imageOffset":1804633,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":63,"imageIndex":6},{"imageOffset":3688360,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":72,"imageIndex":6},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088250,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7446760,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":0},{"imageOffset":7446409,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088251,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7446760,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":0},{"imageOffset":7446409,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088252,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7446760,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":0},{"imageOffset":7446409,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088253,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7446760,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":0},{"imageOffset":7446409,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088254,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7446760,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":0},{"imageOffset":7446409,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088256,"frames":[{"imageOffset":32914,"symbol":"__accept","symbolLocation":10,"imageIndex":2},{"imageOffset":17288,"symbol":"sock_accept_impl","symbolLocation":24,"imageIndex":7},{"imageOffset":18402,"symbol":"sock_call_ex","symbolLocation":402,"imageIndex":7},{"imageOffset":8320,"symbol":"sock_accept","symbolLocation":144,"imageIndex":7},{"imageOffset":146528343,"symbol":"method_vectorcall_NOARGS","symbolLocation":135,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":146499279,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":0},{"imageOffset":148186038,"symbol":"thread_run","symbolLocation":70,"imageIndex":0},{"imageOffset":147859513,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088257,"frames":[{"imageOffset":40282,"symbol":"__select","symbolLocation":10,"imageIndex":2},{"imageOffset":148179228,"symbol":"time_sleep","symbolLocation":140,"imageIndex":0},{"imageOffset":146777237,"symbol":"cfunction_vectorcall_O","symbolLocation":277,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479434,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30538,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":146499279,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":0},{"imageOffset":148186038,"symbol":"thread_run","symbolLocation":70,"imageIndex":0},{"imageOffset":147859513,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088265,"frames":[{"imageOffset":32938,"symbol":"poll","symbolLocation":10,"imageIndex":2},{"imageOffset":7523,"symbol":"select_poll_poll","symbolLocation":291,"imageIndex":8},{"imageOffset":146527852,"symbol":"method_vectorcall_FASTCALL","symbolLocation":140,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479596,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30700,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":146499116,"symbol":"method_vectorcall","symbolLocation":204,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479763,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30867,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":146499279,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":0},{"imageOffset":148186038,"symbol":"thread_run","symbolLocation":70,"imageIndex":0},{"imageOffset":147859513,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088294,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":2},{"imageOffset":523485,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":9},{"imageOffset":516968,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":9},{"imageOffset":513964,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":9},{"imageOffset":1753070,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":10},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2088416,"frames":[{"imageOffset":40282,"symbol":"__select","symbolLocation":10,"imageIndex":2},{"imageOffset":148179228,"symbol":"time_sleep","symbolLocation":140,"imageIndex":0},{"imageOffset":146777237,"symbol":"cfunction_vectorcall_O","symbolLocation":277,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479434,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30538,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":147491823,"symbol":"call_function","symbolLocation":431,"imageIndex":0},{"imageOffset":147479397,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":30501,"imageIndex":0},{"imageOffset":147448593,"symbol":"_PyEval_Vector","symbolLocation":145,"imageIndex":0},{"imageOffset":146499279,"symbol":"method_vectorcall","symbolLocation":367,"imageIndex":0},{"imageOffset":148186038,"symbol":"thread_run","symbolLocation":70,"imageIndex":0},{"imageOffset":147859513,"symbol":"pythread_wrapper","symbolLocation":25,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2126869,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":2126949,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7446760,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":0},{"imageOffset":7446409,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2126950,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7446760,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":0},{"imageOffset":7446409,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":0},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":4},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":4}]},{"id":2127636,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":2127637,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]},{"id":2127646,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":4}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4405927936,
    "CFBundleShortVersionString" : "3.1.2",
    "CFBundleIdentifier" : "org.blenderfoundation.blender",
    "size" : 211075072,
    "uuid" : "886d906a-93f0-3952-a46f-144e5205f719",
    "path" : "\/Applications\/Blender 3.1.2.app\/Contents\/MacOS\/Blender",
    "name" : "Blender",
    "CFBundleVersion" : "3.1.2 2022-04-01"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4992274432,
    "size" : 442368,
    "uuid" : "dd9e80de-fb3b-349b-96a4-46874ad34d11",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703654707200,
    "size" : 229376,
    "uuid" : "26a59789-b846-3ed4-96dc-8dbef3c0c8e7",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703653134336,
    "size" : 290816,
    "uuid" : "31d69d55-9895-326c-ad61-621c5ca87314",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703654936576,
    "size" : 49152,
    "uuid" : "2f6c275d-7e14-3d31-a924-e1bb41d2415f",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703800434688,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 139264,
    "uuid" : "0b849791-3a62-33d1-8cf1-9c612a9d8e18",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703681208320,
    "CFBundleShortVersionString" : "5.0",
    "CFBundleIdentifier" : "com.apple.audio.CoreAudio",
    "size" : 7553024,
    "uuid" : "e432684f-546f-3931-af3e-a0281c23a244",
    "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
    "name" : "CoreAudio",
    "CFBundleVersion" : "5.0"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 5091225600,
    "size" : 57344,
    "uuid" : "099583aa-a77b-35dd-b414-f30dbc3a62c2",
    "path" : "\/Applications\/Blender 3.1.2.app\/Contents\/Resources\/3.1\/python\/lib\/python3.10\/lib-dynload\/_socket.cpython-310-darwin.so",
    "name" : "_socket.cpython-310-darwin.so"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4860919808,
    "size" : 20480,
    "uuid" : "16f40aa0-5cbc-3ea0-92f2-cca27bea0643",
    "path" : "\/Applications\/Blender 3.1.2.app\/Contents\/Resources\/3.1\/python\/lib\/python3.10\/lib-dynload\/select.cpython-310-darwin.so",
    "name" : "select.cpython-310-darwin.so"
    "source" : "P",
    "arch" : "x86_64h",
    "base" : 140703655251968,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5251072,
    "uuid" : "743f0cb7-e962-3e42-8653-7bd141129561",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1858.112"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703699709952,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15261696,
    "uuid" : "36ec7e1b-ab12-377b-b3eb-ffc5baabee9f",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2113.40.126"
  "sharedCache" : {
  "base" : 140703651663872,
  "size" : 15224815616,
  "uuid" : "341ea950-3974-372a-a140-92d2252fd87c"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.5G resident=0K(0%) swapped_out_or_unallocated=1.5G(100%)\nWritable regions: Total=1.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.7G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               128K        1 \nActivity Tracing                   256K        1 \nCG backing stores                 3840K        4 \nCG image                            96K        8 \nColorSync                          100K        9 \nCoreAnimation                      124K        7 \nCoreGraphics                        12K        2 \nCoreImage                            4K        1 \nCoreUI image data                 1036K        7 \nFoundation                          16K        1 \nKernel Alloc Once                    8K        1 \nMALLOC                             1.0G      593 \nMALLOC guard page                   32K        8 \nMALLOC_LARGE (reserved)            256K        2         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           256.0M        1         reserved VM address space (unallocated)\nOpenGL GLSL                        256K        3 \nSTACK GUARD                         96K       24 \nStack                             99.7M       26 \nStack Guard                          4K        1 \nVM_ALLOCATE                      186.9M      329 \nVM_ALLOCATE (reserved)            96.0M        2         reserved VM address space (unallocated)\n__DATA                           110.4M      572 \n__DATA_CONST                      29.2M      324 \n__DATA_DIRTY                      1542K      195 \n__FONT_DATA                          4K        1 \n__GLSLBUILTINS                    5176K        1 \n__LINKEDIT                       719.8M       77 \n__OBJC_RO                         82.6M        1 \n__OBJC_RW                         3200K        2 \n__TEXT                           776.4M      573 \n__UNICODE                          592K        1 \ndyld private memory               1152K        3 \nmapped file                      172.9M       28 \nshared memory                     1284K       17 \n===========                     =======  ======= \nTOTAL                              3.5G     2826 \nTOTAL, minus reserved VM space     3.2G     2826 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "queue" : "com.apple.main-thread"
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "5fc94383418129005b4e9ae0",
      "factorPackIds" : {
      "deploymentId" : 240000370
      "rolloutId" : "607844aa04477260f58a8077",
      "factorPackIds" : {
        "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"
      "deploymentId" : 240000066
  "experiments" : [
Model: iMac19,1, BootROM 1731.100.125.0.0, 6 processors, 6-Core Intel Core i5, 3 GHz, 16 GB, SMC 2.46f12
Graphics: Radeon Pro 570X, Radeon Pro 570X, PCIe, 4 GB
Display: iMac, Retina 5K (5120 x 2880), Main, MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 8 GB, DDR4, 2667 MHz, Micron, 8ATF1G64HZ-2G6E3
Memory Module: BANK 2/ChannelB-DIMM0, 8 GB, DDR4, 2667 MHz, Micron, 8ATF1G64HZ-2G6E3
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Ethernet, Ethernet, en0
USB Device: USB31Bus
USB Device: FaceTime HD Camera (Built-in)
USB Device: lenovo USB Optical Mouse
Thunderbolt Bus: iMac, Apple Inc., 47.5
Related Objects
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.May 10 2022, 6:30 AM
Hi, thanks for the report. I'm unable to recreate crash with provided info.
What changes you've done to the mesh/scene before undoing them?
Can you test again with factory startup?: FileDefaultsLoad Factory Settings
