Object doens´t mode, scale, rotate on 3.3.0
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Hi,
I would like to report a bug.
When importing an image reference, it can´t move, scale or rotate on Blender 3.3.0 alpha version.
(I already checked if it was my mistake disabling "disable selection" option.)
In 3.1 it´s working fine.
Thank you
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.May 12 2022, 5:30 AM
Hi, thanks for the report. Information is incomplete (system info, reproducing steps are missing)
Similar issues has been fixed yesterday T97771, T97996 with this commit rB5045968f24b5d7891a77021722017e93ca02f8cb
Please test again in latest development builds: https://builder.blender.org/download/daily/
If that doesn't solve the issue, give us exact steps for reproducing it.
You can always submit report from installed blender version: HelpReport a Bug
This will add all necessary info about your system, current blender version. So you don't have to fill these filed manually
I assume that commit has solved the issue for you as well.
