Material set to default on Remesh modifier after geometry nodes modifier primitive object and set material
Closed, DuplicatePublic
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.51
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-05-16 18:20, hash: rB8c4bd02b067a
When you use the remesh modifier after a geometry nodes(GN) modifier where the GN is made from a primitive and a material is set on it, the remesh modifier will not keep the set material, instead it will revert to the default material.
Also, interestingly enough it only happens when material is set on a geometry node primitive. And the material is kept when the original input geometry is fed through the geometry node modifier.
(there is a work around to make a GN after the remesh modifier, however is impractical. And I don't know if doing this is how it was intended to work)
Open attached blend file
turn on and off the remesh modifier visibility in the viewport
Thanks Blender Developers!! What you do is so cool! Have a nice day
Hi, thanks for the report. If I understand correctly, this problem is already mentioned in T93455: Set Material Node does not reuse existing empty slot
I'll close this as duplicate.
