Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.85
Also confirmed on
Graphics card: GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 3.2.0 Beta, branch: master, commit date: 2022-05-16 16:16, hash: rBa2dacefb4636
Worked: 3.1.0 Master
Caused by rB21e72496a629: Fix T96728: 'Automatic Constraint' using the wrong orientation
Automatic Constraint, to lock an action to an axis, doesn't work properly if the cursor is not moving.
For operations such as scale, moving, it doesn't work at all. For rotating, it always defaults to the Z axis. For extruding, it still works as intended.
The behaviour is the same when trying to lock on a single axis or on a plane, also when using either object or edit mode.
More details:
- On node editors (geometry, shader ...), Automatic Constraint works for moving, but not for scaling.
- On the UV editor and the graph editor, moving and scaling don't work.
- Based on the default startup.
- Try to move an object and use the automatic constraint (middle mouse click), with the cursor still. It will not confirm the action.
- Repeat the step before, but now move the mouse while clicking the middle mouse button. This time, the action should work.
- If needed, repeat the same with other operations, such as scale, rotate and extrude, and on other workspaces metioned above.
