Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.77
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Worked: (2.8)
In Sculpt mode, I can't bring up the grid when I Shift R and I Crash when I Ctrl R.
My workspace is set for 3D Printing, So I units is set for Millimeters and unit scale is set at .001
Add mesh
cube
size 250 mm
Subdivide Modifier 3 levels
Sculpt mode
Shift-R (no Grid just square)
Ctrl-R (Crash)
Did a Factory default settings and did the same thing as above except used the default cube at 2 mm. the Shift-R works and the Ctrl-R works without crashing. when I size up the cube to 250 mm it starts the problem again.
