Operating system: Windows-8.1 64 Bits
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 4.5.0 NVIDIA 466.47
Broken: 3.3.0 Alpha, commit date: 2022-05-30 17:30, branch: master, hash: ca5939170461 &
3.2.0 Beta, commit date: 2022-05-29 19:19, branch: master, hash: 32bf6455a019
Worked: 3.2.0 Alpha, commit date: 2022-03-22 22:06, branch: master, hash: 5c27391b0f8c
Curves have some named attributes that don't always have dedicated nodes like "Radius" but are still available to Geometry Nodes, being visible in the Spreadsheets and everything. Some of them are: knots_mode, curve_type, nurbs_order, and nurbs_weight.
In 3.2 alpha it was possible to set them through GN (not sure about the latest version it worked). In most recent builds curve_type and knots_mode are broken. (Edit: I just found out nurbs_order is also broken)
This is the expected result of setting each one of the three attributes at a time:
Curve 1 is the original one for comparison.
Curve 2 had the nurbs_weight of control point 2 altered, included as an example of a "nodeless" named attribute that fully works.
Curve 3, knots_mode set to its original value.
Curve 4, curve_type set to its original value.
With the important note that even in 3.2 setting either curve_type or knots_mode makes them disappear from the spreadhseet, complicating debugging. Unlike them, nurbs_weight updates fine.
This is what happens in 3.3:
The bottom curves shouldn't change, just like in 3.2, because they're being set to their original values.
- Add a Store Named Attribute node to a NURBS curve, setting the Name to either knots_mode, curve_type, or nurbs_order and then typing the original value in Value.
