Operating system: Windows 10
Graphics card: RX 580 4GB
Broken: 3.1.2 release (.msi) from the site.
Described separately:
Windows Store version.
3.2.0 (.msi) from builder.blender.org/download/daily/
I am very new to Blender, just installed it and it crashes when I simply interact with UI elements. At least those on top, such as Edit->Preferences click on something there. Or when I try to navigate files when I simply select disks even. And I can't find any logs in temp.
Also UI flickers sometimes.
Deleting userpref.blend didn't help. Drivers are the latest.
Strangely when I open Blender via .cmd files (such as blender_debug_log.cmd or blender_factory_startup) I was able to navigate UI a bit further, even to save project. But the whole program still closes when I close Edit->Preferences window or try to import (.fbx). Log produced after this is empty.
I'm not a Python programmer but I actually remembered I had to set PYTHONPATH in Environment Variables back in a day. Now I deleted it, restarted and reinstalled. Didn't help.
Windows Store version: similar thing. Crashes occasionally, UI flickers. I checked Temp and first time log actually has something. Attached it. Even though untitled2.blend is just a default cube scene attached it aswell. Just in case.
Daily 3.2.0: everything is the same. blender.crash.txt is empty.
Install (first time ever)->Launch in a standard way->interact with UI.
