Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96
Broken: version: 3.2.0, branch: master, commit date: 2022-06-07 18:03, hash: rB2161a892519e
Having a Dense scene while "Show Overlays" is activated, causes huge viewport lag in both Solid and rendered mode cycles, by deactivating or disabling "Show overlays" viewport becomes smooth no matter how dense the scene is
I've attached a test file to explain the issue so first thing you'll find a Box with a subd modifier scattered on a plane, test the original settings i made if you don't notice performance drop in viewport navigations frame rate (pan/rotate) you'll need to increase the scatter count till you feel the lag, then compare the viewport navigation speed when "Show Overlayes" turned ON and OFF, in both cycles and solid mode
