blender crash sometime
Closed, DuplicatePublic
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.59
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash: rBe05e1e369187
sometime crashing happened. especially when running Remesh in sculpting and when reducing the voxel size (less than 0.05m). the computer has even reset several times during working blender.
This comment was removed by Saeed rahimzadeh (SRZ).
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Jul 5 2022, 10:02 PM
Thanks for the report, but unfortunately this can't be triaged as a complete bug report.
For the development team to be able to help, there needs to be reproducible steps.
And the log files provided unfortunately do not indicate what could be causing the crash.
Can you provide the coin source.crash.txt file located at C:\Users\SRZ\AppData\Local\Temp\coin source.crash.txt as shown in the blender_debug_output.txt?
Note that since it involves Remesh and voxel size, this could be the same problem described in T77868: Remesh Voxel Size can be much to small by default (leading to crashes). 'Edit Voxel Size' operator can have wrong range. This could be a limitation on available memory space.
