copy UV option doesn't work correctly
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.2.1, branch: master, commit date: 2022-07-05 15:44, hash: rBa2d59b2dac9e
Link/Transfer Data > copy UV maps gives wrong result.
Open the file and try to copy the "chainmail1" object UV to "chainmail2" object.
I get the same wrong result even with the Data Transfer Modifier.
Please check also the attached video.
Thank you
Max
The mesh is not the same.
If we compare the indices of the vertices, they are in different positions.
The Copy UV operator is a simple operator that does not consider the mesh topology.
So while not useful in many cases, it works as designed and is not a bug.
Data Transfer Modifier, works quite differently.
I tested it and there were no problems.
Thanks for the reply.
In that case the tool tip should say (needs matching vertex order) instead of ( needs matching geometry)
